06-14-2023, 12:10 AM | #1 |
Average KKT User
Drives: 2001 Echo Join Date: May 2020
Cheap Strong Rods
Simple info dump
Nissan GA16DE Connecting rods fit in our engines with slight machine work Which includes side clearancing rods. These are bigger known for 200 - 250hp no problem from what I've read. These are good because I got my set for 67$ from a upullit or 16.75$ each. Nissan Big End Diameter is: 1.6932inch or 43.01mm Nissan Wristpin Size: .7480inch or 19mm (Perfect fit for YCP 75mm Vitara Pistons) Nissan Side Clearance: .856inch or 21.74mm Toyota Big End Diameter is: 1.6929inch or 43.00mm Toyota Wristpin Size: .7080 or 17.98mm Toyota Side Clearance: .706inch or 17.93mm Problem Side Clearance Needs .150inch removed from the rod / .075inch from each side Ill Edit Once I get Plastigauge to double check clearence and if I come up with more info about them. Yes they fit the on the crank once side clearancing is done with out any problems and spin freely. If you have any questions or concerns send them my way incase I don't think of a problem that could occur. Much thanks. Last edited by Cletus Garfunkle; 06-14-2023 at 12:11 AM. Reason: added units to numbers |
06-16-2023, 09:57 PM | #2 |
Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
interesting find, are they cast or forged?
06-17-2023, 06:41 PM | #3 |
Average KKT User
I Believe these are forged rods Pics of Rods Below
Last edited by Cletus Garfunkle; 06-17-2023 at 06:45 PM. Reason: Change Size Of Pics |
Thread Tools | |
Display Modes | |
