![]() Drives: 07 Yaris HB Join Date: Aug 2023
2007 2dr HB part out
Hi,
I've decided it's time for my 'golf cart' to go. Unfortunately, the New England salt has claimed the underside. Suspension, rear brakes and wheel bearings are failing as well. Too bad really, because the car fires right up no matter what temp! Clutch and transmission shift smooth, too. Interior isn't bad either. I'm considering selling off parts. Let me know what you might need, and/or offer. There's currently 110xxx miles on the odometer. Thanks, J |
![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
do you have the original climate cpntrol panel and radio bezel with the ac vents? ill take those, and please leave the knobs and vents in it as the little tabs that hold them in usually break if you remove them, lemme know how much you want, shipping to zip: 85295, gilbert,az
I do, but can you tell me how to remove (without breaking)?
![]() ![]() Drives: 07 AT & 08 MT Yaris HB 3dr Join Date: Nov 2021
You have to take the trim that runs down each side of the radio/climate controls first. Then the other pieces just pop right out.
Here's a video of the stereo removal but pretty much tells you what you need to know. Start at 2:40 for trim removal. |
yes, so first pull up the side panels where the hazard switch is, then pull out the other side that has the passenger airbag indicator, then the instrument cluster panel pulls out, then pull the radio bezel out with the ac vents in tact, then the climate control panel, you can just cut the wires if the car is getting scrapped
Had it out before I even read this... A no brainer, really! :-)
Send me a message on it. |
![]() Drives: 2010 Yaris Join Date: Mar 2023
I would be interested in the stock airbox and the hood prop, need both shipped to 68510
Do you by chance have a tachometer built into the speedometer?
no, just the speedo.
It's all gone
![]() Drives: 2006 Yaris 2dr hb manual Join Date: Oct 2021
Cars gone or the speedo? I'd take the drivers side headlight if available
| $700 2007 Yaris 2DR Hatchback | hodginsa | New YARIS Purchase Forum | 63 | 11-13-2017 12:36 AM |
| 2007 Yaris: jerky part throttle and trans. freewheel | Cartel | General Yaris / Vitz Discussion | 0 | 03-04-2017 04:19 PM |
| DIY - Carbon fiber wrapping | Brian | Wash, Wax, Detailing, Exterior Repairs | 15 | 07-10-2016 01:34 PM |
| 2007 Registration and Insurance | Vitz-to | General Yaris / Vitz Discussion | 21 | 03-28-2006 10:57 PM |
