01-01-2024, 08:38 PM | #1 |
Drives: yaris Join Date: Nov 2018
Cold Start ticking noise, lifters?
So when it gets really cold my engine starts to tick a few seconds after starting it then goes away. It seems to be coming from the valvetrain like a lifter isn't priming. Is this a common issue? It doesn't rattle right away like a cam adjuster issue, the video below you can hear the metallic tick starting a few second after the engine is on( When I put my hand on the engine), I cut it a bit short but it goes away shortly after I ended the video.
There is no noise unless it gets just below freezing outside and sitting overnight. On warmer days it starts very smoothly with no ticking. https://www.youtube.com/shorts/jJP-ZAewyas Last edited by ltwargssf; 01-01-2024 at 10:08 PM. |
01-02-2024, 12:16 PM | #2 |
Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
if you have the 1nzfe, this engine does not have lifters, it has shim over bucket, it is possible that the valve adjustment is out of whack and is a little more complex to get measurements correct, i recently have done a head gasket job on a 1nzfe that had 290,000 miles on it and while i was there i checked the valve clearance and they were all in spec right smack in the middle of the range, i would not worry to much about it
01-11-2024, 10:50 PM | #3 | |
Gen 3 > Gen 2
Drives: NCP131, F-150 Join Date: Jul 2019
I don't have a block heater and still have the original 10 year old battery in it, its started every day this week so far. Knock on wood.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2013 Rav4 LE AWD Autotragic - Wife's |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Have engine knocking noise, assume it's lifters, but... | just1witness | DIY / Maintenance / Service | 5 | 04-10-2023 04:54 PM |
Metallic noise after starting on cold morning | CrimsonEclipse | DIY / Maintenance / Service | 4 | 11-20-2022 05:46 PM |
04 Echo won't cold start....... | Ronnie V | DIY / Maintenance / Service | 3 | 03-31-2022 07:29 PM |
Valve Noise | barryware | DIY / Maintenance / Service | 25 | 02-13-2013 02:39 PM |
longer turn over on start w/ cold weather | manborn | General Yaris / Vitz Discussion | 20 | 02-04-2007 11:35 PM |
