Old 01-01-2025, 10:23 PM   #1
yaris2014toyota
Drives: Yaris 2014 2-Door LE
belt squeak
Yaris 2014 LE Hatchback 2-door
Can't get rid of the belt squeak when starting the car.
Used 2 different brands of belt dressing. It goes away for a day, then comes back.
Difficult to tighten the belt the way the system is designed (one has to pull the alternator forward, takes a lot of strength).
Got any suggestions I could try?
yaris2014toyota is offline   Reply With Quote
Old 01-03-2025, 01:53 AM   #2
komichal
I went through the same as I did not believe the posts here about the squeaking belts. My car mechanic was already desperate. I tried 3 belt brands (Continental, Gates and something else). They all squeaked, regardless the tension. Changed the pulleys. Nothing helped.
Then I bought the original Toyota belt. Aaaand... the squeak is gone. Right after the change.
Save your time and bucks and go straight for the Toyota belt.
Old 01-08-2025, 09:05 PM   #3
CrimsonEclipse
Drives: .
There is a thing with Toyotas, if you turn the ignition on then IMMEDIATELY start the engine, you'll get alternator squeak.
If you turn the ignition on, wait 3 seconds, THEN start the engine, no squeak.
My guess is extra time for the software to get to the alternator regulation.
CrimsonEclipse is offline   Reply With Quote
Old 01-10-2025, 05:10 AM   #4
komichal
This 3 second break did not help me with my squeak. Only the Toyota belt did.
2012 Yaris LE - Belt Squeaking Daedalus DIY / Maintenance / Service 1 10-09-2023 05:15 PM
Determining proper tension for new serpentine belt RMcG DIY / Maintenance / Service 11 12-30-2021 06:01 AM
Unexpected Seat Belt Light Flashing ern-diz DIY / Maintenance / Service 19 09-23-2018 01:03 AM
Blitz Supercharger Belt Slip @ Higher RPM? Freestylin Forced Induction Forum 20 09-06-2017 07:32 AM
DIY how to change you belt in 10 minutes without breaking VVTI solenoid YarisSedan DIY / Maintenance / Service 2 04-12-2013 10:41 AM
