Drives: 2011 Toyota Yaris Join Date: Feb 2025
Struts
I have 2011 Yaris with 80k miles. A shop I've always trusted did a courtesy inspection and said front struts are so bad that one side could drop to the ground. I took it to another shop to do a complete vehicle inspection and they said everything is fine. Car doesn't bounce, rides fine, but very occasionally makes a slight click when turning. First shop said that was not sway bar links, but the struts.
![]() ![]() Drives: . Join Date: Mar 2019
The only your car could "drop to the ground" is if the spring broke.
The click is probably your tie rods, ball joints or, anti sway links. Likely not a big deal unless you feel a control change or the steering does something weird going over a bump or in a turn. |
![]() ![]() ![]() ![]() Join Date: Feb 2010
At 14 years old and 80,000 miles....your struts will need replaced very soon along with the sway bar links. Don't buy Moog sway bar links...they need lubed and there is almost no room to get a grease gun hose to the fittings. Buy sealed links.
![]() Drives: CLAPPED 2007 Yaris Sedan S Join Date: Feb 2025
When it comes to replacing the struts, I have found that it is nearly impossible to find coils for the rear. Because the rear is a independent coil/shock setup.
Rear coils at Toyotapartsdeal, PN 48231-52A51...$109 each. I have 252,000 miles on my Yaris and luckily never had to replace one of those. I have replaced the rear shocks and front struts twice.
| Replacing front struts and rear shocks questions | stiglitz | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 10-25-2022 02:44 PM |
| Struts 2007 Yaris | cort21 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 02-10-2018 09:37 AM |
| 09 Sedan Struts?? | supmet | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 02-01-2010 01:20 PM |
| nf210s + trd struts?? | static808 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 04-26-2007 11:38 AM |
| using the tops from stock struts with new trd struts? | tekmoe | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 01-13-2007 11:58 AM |
