ECU Wiring Diagram?
anyone have the ecu diagram for an 07 yaris hatch? searched, but can't find it...
![]() ![]() ![]() Drives: 2007 Yaris Sedan Join Date: Apr 2009
Closest I have seen is in section 5 of the EWD.PDF file part of the service manual. I downloaded from a thread here.
Here's a chart that I put together. The connector pinouts are at the end of the EWD. I went through the EWDs to figure out every used pin on the two connectors.
In case you are wondering about the highlighting - They are the pins needed to fire up and ECM on the bench. The ones highlighted in red are the ones that need +12V and the yellows are the ones that need to be grounded. Yaris ECM.pdf |
wow, very nice!!
Well done CTScott!
Much
Drives: yaris ts Join Date: Oct 2010
Hellow all
I bought an 1nz-fet - NCP13 Vitz TRD engine with turbo from yahoo jpctrade auction. By trying to put the motor on my car we found the following problem: The 2 sockets with wire from ecu to car speedometer are missing. I attach a photograph (111.jpg) to show the missing sockets. ![]() So we found 2 sockets which match but we haven't the terminals of ecm (ecu pinout - wiring diagram) to construct the cables. In addition to the above my car is Toyota Yaris TS 1.5- NCP13 2002 and the vitz trd engine is from a vitz rs turbo 2003 model (facelift). So the 2 harnesses are different. I want to ask you someone have the pinout diagram for this or where could i find it? Thanks in advance |
![]() ![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Jul 2010
Goo luck finding that. Ouch.....
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats." xbgod - 9/23/2010 |
#9 | |
CT just has every wring scheme imaginable!!!
You keep on surprising me:)
Drives: echo Join Date: Apr 2015
1nzfe engine pin-outs
#12 | |
Drives: NCP10 Vitz 00 Join Date: Sep 2015
HI MAte,
I have the same problem also, would you please forward pdf diagram also? Thank for your help. BR. Kaws |
![]() Drives: Yaris ts Join Date: May 2018
does anyone have the diagram?
Could tell me where i can find it Just build a yaris TS with turbo and need the pinout diagram for the ECU vitz turbo (1nz-fet - NCP13 Vitz TRD) thanks |
![]() Drives: 2005 Scion xb Join Date: Jun 2018
I’m in need of the diagram for the 1NZ-FET trd Turbo ecu if anybody would be so kind as to share it :)
![]() Drives: 2007 Yaris Sedan Join Date: Aug 2022
In need of the diagram for the 1nz turbo also can someone help if anyone is still out there?
Drives: Yaris Join Date: May 2025
Anybody knows which programmer use to program a 2023 yaris with a M [4A] blade key I'm need make replacement key
| Tags |
| ecu wiring, ecu wiring diagram, wiring |
| Installing Trailer Light Harness | vandallen | DIY / Maintenance / Service | 7 | 06-10-2024 11:06 AM |
| FS: Motec M4 Standalone ECU w/ Ignition Expander | Biggie™ | Items for Sale by private party | 6 | 10-20-2009 03:36 PM |
| Tricking the ECU to Relearn AF map | gwasabi | Performance Modifications | 126 | 05-16-2009 07:15 PM |
| Wiring color code for 2008 LB? | charles nelson | DIY / Maintenance / Service | 0 | 04-25-2009 04:56 PM |
| NEED TPMS Wiring Diagram please | mikenacarato | DIY / Maintenance / Service | 9 | 02-12-2009 12:55 AM |
