Old 01-03-2022, 03:47 AM   #1
toyotavios_11
Drives: Toyota Vios
ABS light on randomly
Model 2011 yaris sedan.
ABS light comes on randomly after some distance of driving and the wheel turns hot.
The light will eventually come off after stopping for a few moments and the wheel temperature get colder.
Or clear the code using OBD2 scanner.
Pull the code and get DTC C1402 "Malfunction in Front Speed Sensor LH Circuit".
Already tried to clean both ABS sensor tip and ring sensor, but error is still on and off.
Does this mean i have bad ABS sensor?
toyotavios_11 is offline   Reply With Quote
HELP! ABS & BRAKE LIGHT ON SIMULTANEOUSLY! mizhgolightly DIY / Maintenance / Service 45 05-03-2022 03:59 PM
parking brake light on & abs light on ! car stuck in 2nd gear !!! Bony_ahmed DIY / Maintenance / Service 3 04-29-2019 07:57 AM
Yaris 2007 ABS & Brake light issue after wheel bearing change DevilzMafia DIY / Maintenance / Service 4 01-17-2013 10:24 PM
Brake & ABS Light On JeffRapp DIY / Maintenance / Service 3 01-05-2013 12:10 AM
Sharing and Need Help! Lowered but abs light came on! tobymak21 California 0 08-08-2012 09:48 PM
