Old 06-14-2007, 04:29 AM   #1
chino_potato
Boxeo
Drives: 07 yaris RS
Disable DRL and keep Fog Light function!!
Could someone please post a new, straight forward, clear way to disable the DRL and keep the Fog light function. Canadian Yaris Drivers will surely thank you.
chino_potato is offline   Reply With Quote
Old 06-14-2007, 05:56 AM   #2
Edd
Drives: None
Out of curiosity, why do you wish to do this? Don't you want as many lights on as possible in a fog?
Edd is offline   Reply With Quote
Old 06-23-2007, 07:29 AM   #3
earljail
earljail's Avatar
Drives: 07 Yaris Hatch 5speed
No, you don't. Having more lights on means more glare back at you. The idea of fog lights is having some lights down really low to the ground so it glares less.
I don't venture out of the Stereo forum often. Would somebody tell me where the DRL relay is?
I'd like to disable them; I hate not being able to turn all lights off, like when you want to keep the car running when you're parked at night.
earljail is offline   Reply With Quote
Old 06-23-2007, 02:01 PM   #4
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Search is your friend! http://www.yarisworld.com/forums/sho...ht=disable+drl
2006 Red Blitzed RS 5-door
Old 06-14-2007, 02:24 PM   #5
Teruyume
Teruyume's Avatar
Drives: 06 Yaris RS
Send a message via MSN to Teruyume
the connector to your DRL relay has one orange wire, Ground that will allow u to control ur fog light.
06 Yaris RS 2Dr HB 5MT Orange
Blitz Compressor
Apexi Power Intake
GP Racing GR-6 15x7
Kumho Ecsta AST 195/50R15
Tanabe DF210
JDM LED Tail lights
Teruyume is offline   Reply With Quote
Old 06-15-2007, 08:40 AM   #6
window_lee
Drives: Yaris RS 2007
I know there is a orange wire but i don't know how to ground it
window_lee is offline   Reply With Quote
Old 06-21-2007, 07:24 AM   #7
window_lee
just connect the orange wire to any metal in your car will be fine
Old 06-21-2007, 11:26 AM   #8
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
yea, do that....
i grounded mine with my radio..
-- Blen
Old 06-21-2007, 12:58 PM   #9
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
ok is the orange wire go all the way to the fog....also does the fog uses negative wire as the switch or is it thru the red(power) wire to turn it on??
Old 06-21-2007, 01:49 PM   #10
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
marcus... I'm not sure what you're trying to say. By grounding the orange wire, you bypass the DRL relay and allow the fogs to be only controlled by the fog switch. The orange wire is only a switching wire, and only has a couple milli-amps flowing through it. When the circuit closes (i.e. fog switch on), it switches the fog light relay which activates the high current circuit that your actual fog lights are on. The orange wire has nothing to do with the actual current thats going to your fog lights.
Also, I'm pretty sure that this would also leave your fog lights on when you turn off the car, so you'll have to remember to shut them off every time or risk draining your battery!
Old 06-21-2007, 02:31 PM   #11
marcus
toyota
marcus's Avatar
got it!!!.. im actually thinkin of switching the grounding wire on fogs to headlight . so when car is on the fogs is on with 10v power running thru it "drl". when headlight is on then fog get 12v and actual headlight is controlled with the fog wire...incase of hid conversion which will be controlled by fog switch instead and you dont need to get rid of the drl...i think itll work just need to switch the fuse as well..
