Old 06-29-2007, 06:06 PM   #1
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
Questions on Shocks
I installed Tanabes Df210 springs awhile back, and i know that lowering a car will wear out stock shocks quicker than they would normally wear out.
1-so about how long would the shocks last on stock springs?
2-how long might the stock shocks last with my 2 inch drop?
3-do the trd shocks fit both the LB and the Sedan or is another case where the lift back gets all the love and the sedan gets left in the rain?
i also have 17's on 215/40 tires if that makes a difference.
Old 06-29-2007, 06:18 PM   #2
Vanderkitten
Vanderkitten's Avatar
Drives: 2007 Yaris Hatchback
Why does lowering a car wear out shocks faster? Changing the way you drive with a lowered car (faster) will wear them out faster.
Shocks will get 60-100k ususally before needing replacing, depending on how you drive, temperatures, etc.
Many times when you go to a stiffer spring rate, the shocks rebound stroke is faster, and therefore the shocks get hotter... but I don't know how that effects life-span.
Anyhow, when yours wear out I have 2 sets of stockers to seel you cheap! I would imagine the $150 springs would wear out quicker than the OEM shocks.
D
Dave V- Creator-Vanderkitten- Clothing for Women Who Kick Ass!
Many thanks to our sponsors:
Weapon-R http://weapon-r.com
Megan Racing http://www.meganracing.com
Les Schwab Tires http://www.lesschwab.com
317 graphics http://www.317graphics.com
Vanderkitten is offline   Reply With Quote
Old 06-29-2007, 06:18 PM   #3
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
the trd shocks fit both. if you ride in warm weather on smooth roads, I suspect the stock shocks will last long enough so you won't have to worry about. In the opposition, on poor roads and cold weather the stock shocks could blow in less that 1 year
hystria is offline   Reply With Quote
Old 06-29-2007, 06:28 PM   #4
whooppee777
i'm not exactly sure how shocks work on the inside but i assume that decreasing the amount of space that the shock has to rebound from bumps and holes would wear them out sooner than if that space hadnt been decreased. excess heat will weaken the metal over time and i guess i can see how cold will fuck them up. i just didnt know the average lifespan of shocks.
Old 06-29-2007, 06:43 PM   #5
njyaris
YARIS NEWBIE
njyaris's Avatar
Drives: YARIS 07 LIFTBACK
Send a message via AIM to njyaris Send a message via Yahoo to njyaris
good question .. i'm dropping my car soon .. and wondered the same thing
Hudson County, New Jersey
njyaris is offline   Reply With Quote
Old 06-29-2007, 07:17 PM   #6
YarisGuy
Drives: 2006 Yaris
The factory equipment is designed to have a certain amount of travel, in this case up and down. When you lower the car you change this ratio and the shock has to contract and expand differently. Going TOO low will blow the factory shock. Aftermarket shocks are often designed to travel in a shorter "field" and are designed to fit lowered suspensions.
I like Koni shocks myself, but I honestly have not looked into too many suspension mods for the Yaris just yet.
It's a red yaris
YarisGuy is offline   Reply With Quote
Old 06-29-2007, 07:19 PM   #7
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
This has been discussed 1,000,000,000 times. The DF210 were designed to work with the factory equipment. You should be ok for a very long time. If you wanted to replace the dampers with something stiffer you would feel the difference driving.
SPONSORED BY
Hello and some questions for you..... suttonschinook General Yaris / Vitz Discussion 10 07-03-2007 08:15 PM
Lowering, shocks question... ToTo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 05-23-2007 12:55 PM
Brakes and Shocks question jamal1984 DIY / Maintenance / Service 6 03-18-2007 05:26 PM
Shocks upgrade??? CASTREX Performance Modifications 24 01-29-2007 02:13 PM
Questions, questions... littlecarlove Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-21-2006 02:42 PM
