Old 06-24-2007, 11:59 PM   #1
churp
Clean and (dis)Functional
churp's Avatar
DIY Hood Gas Spring
For the DIY'er that wants to save a buck and doesn't want to drill holes in his Yaris when installing a hood gas cylinder....here's a solution:
Tools needed for installation:
1/2" open or box end wrench
12 mm socket
14 mm socket
ratchet w/extension
Purchased items from MSC Industrial Supply (online):
MSC #: 00483743----------------$15.43----- 30# cyl w 7" stroke
MSC #: 32912198---2@.72-----$1.44------- ball stud
MSC #: 32912206---2@.24-----$0.48 -------retainer clip
total---------------------------------$17.35
Misc. items:
5/16" nut....2 req'd
5/16" lock washers....4 req'd
Fabricated items: (see pics for clarification)
upper bracket.............1" angle aproximately 3" long with 2 holes (5/16" and 7/16" diameter)
lower bracket............1/4" X 1" X 9" steel,with 2 holes (5/16" and 7/16" diameter) the 1st one 6" from the bend and the 2nd 1.5" from the bend.
NOTE: Cylinder is positioned wrong in most of these pic's. The shaft always attaches to the lower bracket while the cylinder (black) attaches to the top bracket.
____________
Old School Cobble Jockey
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 07:41 PM
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 10:26 PM
DIY Hood Cylinder churp Cosmetic Modifications (Exterior/Interior) 46 06-25-2007 06:46 AM
Before you buy . . . check that hood! woof General Yaris / Vitz Discussion 4 12-02-2006 06:14 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 09:07 AM
