I used to have 1700 posts
megan header issues
has anyone had trouble installing their megan header or and weird vibration noises afterwards? what happened to the thread that had the dyno results for the header?
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
if I'm not mistakin' in chris's diy you need to re-torque them there bolts shortly there after but I ain't no certified mechanic, it could be a cat hung up in there or somethin'
pop the hood
SPONSORED BY
his exact words were "retorque to specs" and i couldnt find any specs so i just tightened the bolts. theres a brace on the lower en of the header that i was unable to put back on because the stock bolt didnt fit the megan header. the wonders of aftermarket parts. i think the lack of the brace is whats making it make the vibrating noise. maybe i dunno
![]() ![]() Drives: 07 HB Join Date: Apr 2007
Personally, after seeing the thread about the 'gains' from this header I opted out of it, but If I recall someone said megan sends the wrong size bolts, and they had to get some other size.
#5 | |
This may or not be the problem in your case, as I dont know where you got yours from. The vibration is coming from the heat shield "shell" just above and around the collector area... take your finger and "flick" on edge of the shield, you will make the noise, and see how very flimsy it is. |
now i see what you're talking about. should i just take that off or what. my friend says i really dont need it. but he is retarded.
Alotof people take it off, basically its just there to say, DONT TOUCH ME IM HOT, to prevent people who dont know how hot the exhaust gets from touching it.
#8 | |
The heat shield on the stock header will not, and is not, designed to fit the Megan Header. |
my Megan header did not come with the correct bolts. Fortunately, my friend at the shop had the correct size.
#10 | |
while looking at the engine in my friends place today the shop manager said my engine was shaking too much and that it looked like my engine was miss firring. but it looked normal to me and if it was miss firring wouldnt it set a code, or wouldnt i feel or hear something as a result of it miss firring? |
It would be unusual for it to misfire, and yes, it would throw a CEL if it did it. Toyota's intelligent tester tool would be able to tell you exactly if that is the problem, so if in doubt, go to your toyota service center and ask them to check it out. My guess is, because of the low idle of the engine, it could look like it's shaking, once it's warmed up. You could always invest in a torque damper, that will keep things in place
TRIM HUNTER
Drives: 2007 BLAZIN BLUE YARIS 3 DR Join Date: May 2006
NOR DID JERKRATT'S....
http://rocklandtoyota.com/IFrame.aspx?iFrameID=2388 TOYOTA PARTS AT A DISCOUNT........ |
Those with hardware issues.. were did you order yours from?
I know of knowone from the original Megan GB way back when, reporting any issues. Wondering what's going on over at Megan, or whoever builds these for them. Sucks. |
#14 |
![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Liftback S (RIP 07) Join Date: Apr 2007
actually my friend was an idiot and thought the studs went somewhere else i have since gotten the studs installed still gotta find where the heat shield is being hit
"It hurts more when its wet" |
#15 |
do you have a link to the c-one torque damper?
#16 |
of course i think i posted one earlier... let me find it and update this post
EDIT: bulletproofautomotive has them... here ask c2auto he might be able to order them also ima go get dressed and try and find that heat shield problem.... be back later
#17 |
it says its for the NCP91 model yaris. would that fit our yaris'? let me know how searching for that noise works out. so i know whether or not to take off my heat collector under there.
#18 |
ok so i went to the dealer today and they said its most likly the donut gasket thingy inbetween the header and the j pipe...... dam i dont got money to buy another donut/gasket.....
| Megan Header Install [pics] | Chris07LB | Performance Modifications | 132 | 09-29-2010 03:41 PM |
| Are We Still Stuck With the 4-1 Headers? | Sabretooth | Performance Modifications | 31 | 02-20-2009 08:57 PM |
| Megan Header Advice | jamal1984 | Cosmetic Modifications (Exterior/Interior) | 1 | 02-20-2007 07:22 PM |
| Weapon-R Header (4-2-1) | CASTREX | Performance Modifications | 28 | 02-19-2007 01:57 PM |
| GROUP BUY - Megan Racing 4-1 Header... | riceboy | Items for Sale by private party | 489 | 01-10-2007 06:45 PM |
