![]() ![]() Drives: '08 Polar White 3dr Join Date: Jun 2007
Req: Head unit suggestions.
Hi all.
I plan on getting a no option 08 Yaris LB and putting in a head unit and also replacing the stock speakers with new 6.5" in front and rear. Requirements: - I need a head unit that pushes 40w RMS x4 or more clean watts. Good clean power, not crap. - I need the head unit to have a true good quality aux line-in. Either front or rear mounted line-in is fine but my first choice would be rear mounted so that I can hide wires. - I do not need/want a unit which would allow me to control my ipod with the head unit controls. I like to have my ipod dash mounted where I can easily see and control it. - I want a head unit that supports HD radio (not a requirement but would be nice) That's it. Technically I don't even care if it didn't have a CD player and was radio only since all my portable music is on my ipod. Does anyone know of any head units out there that would work for me? |
![]() ![]() ![]() ![]() ![]() Drives: LB-Auto-PWR-ABS-Cruise-Springs Join Date: Aug 2006
http://www.crutchfield.com/S-nzc6Ozt...&pg=1&sortBy=3
Read the reviews. I currently have 2 Panansonic receivers and did own a Panasonic car deck that had a digital amp built in. They are all clean and powerful. I think these MOSFET powerstages are also "digital Amps" as well. The big brother... http://www.amazon.com/Panasonic-CQ-C.../dp/B000MXV8DI
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime Get YarAss in gear! RIP - Casey Tatum |
Well, I have been searching for a head unit for a week now and the highest RMS I've seen is 22. You are not talking about the peak power right? Otherwise, I don't even know if there is any head units out there that can give you 40w RMS...
Visit crutchfield.com for and click on overview to view the specifications of head units. |
#4 | |
The Pannny in my truck (CQ-C9700U) http://www.epinions.com/content_175474970244 had 60WX4 peak and it sounded awesome. No distortion either. It was also $400.00.
Down With the Sickness
i beg to differ, i got a panasonic cq-c8803u and it is rated at 70wx4 peak, 31w rms. features digital "t" class amp built in, hd ready, ipod ready, real sweet head unit.
detailed features General features: » CD receiver with built-in Class T amplifier (31 watts RMS/70 peak x 4 channels) » plays CDs, CD-Rs, and CD-RWs (including discs loaded with MP3 and WMA files) » motorized, fold-down, detachable face with color full-motion graphic display » remote control Audio features: » SQ9 9-band equalizer with six preset sound curves » SRS Circle Surround Automotive » high- and low-pass filters with subwoofer level control Expandability: » compatible with optional Panasonic Bluetooth receiver, iPod adapter, satellite radio, CD changer » inputs: auxiliary input (rear RCAs) » outputs: three sets of 5-volt preamp outputs
Strength - Determination - Merciless - Forever Last edited by sdmf; 08-08-2007 at 04:31 AM. |
#7 | |
#8 | |
Why can't they design these head units nicer? Still much nicer than Yaris HU for sure though
i don't think you will ever find one HU that has 40w RMS :)
even my 700$ alpine HU comes with 27w RMS i think. |
Digging around at Crutchfield I spotted this which looks promising...
http://12.4.198.138/S-dcc0m4N53Qm/cgi-bin/ProdView.asp?g=300&tab=detailed_info&i=257kdhdr1 ![]() 20w x 4 RMS and it's MOSFET. It has HD Radio out of the box and I can plug up an ipod adapter to the cd changer input which will charge my ipod and transfer sound but nothing else. It doesn't deactivate or zombie my ipod. Best of all it's $200 at Crutchfield or a bit less on fleabay plus the cost of the ipod adapter. |
i guess 31w rms is the closest to 40, panasonic is the way to go my friend.
Strength - Determination - Merciless - Forever |
Absolutely! Is your deck still available? That is the sweetest thing! How does it sound?
#13 | |
panny head!!!
here's where i got it from, http://www.hookedontronicsbuys.com/s....jsp?cid=25254 not a bad deal for 242.00, fast shipping and great warranty from them.
Dr. Trunk Monkey
Drives: 2007 Red Yaris Join Date: Jul 2007
Cousin Vitz
Drives: Yaris RS 5DR / Vitz RS wannabe Join Date: Mar 2006
Kenwood eXcelon KDC-X791
22W RMS/channel 50W peak/channel Rear mounted auxiliary in Rear mounted USB support (It's a USB cable that's about 1.6 meters, you can route it behind the dash or where ever. You can plug in USB thumb drives) You can plug in your iPod to the USB cable; you would retain all controls on the iPod. (There's a separate cable accessory if you want the head unit to take all controls when the iPod is plugged in, but in your case this isn't necessary) Support for HD radio Short of your requirement for 40w RMS/channel, but I am afraid I haven't seen a head unit with +30w RMS/channel. If you require that sort of power rating, you might want to use a dedicated amplifier to power to your speakers instead of your using the deck's amplifier. http://www.crutchfield.com/S-qMMqMKT...p?i=113KDCX791
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930 Last edited by bigsky2; 08-07-2007 at 10:24 PM. |
Well, they are the best decks on the market... if you don't want to install external amps. The digital amps are just perfect sounding. Match it with some Panasonic speakers, they are incredible and not overpriced: http://www.panasonic.com/consumer_el...sp_default.asp
and you will have a perfect sounding system. Sounds too good to be true, but it is true. The cq-c8803u is so configurable, you can shape it to any sound you want. Other decks just can't compete with their analog circuits. Digital amps are also way more efficent, 95%+. vs 40% to 60% for conventional amps. That means more power to your speakers and less heat generated. Also less load on your alternator, so better MPG! (that last claim about MPG is a stretch, but possible) hehe
Panasonic says "I needed a stereo."
Alpine says "I know my stereos."
Alpines were good back in the day but now they just dont do it for me, panasonic has stepped up their game and i was really impressed with the power output and its features. if you want something that says i needed a stereo get a jensen or pyle. if you want clarity and robust power go with the panny. btw panasonic is a sponsor of the toyota f1 car, pretty sweet seeing a toyota on the screen too.
| srs / airbag light after head unit install? | KwonSau | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 12-24-2008 02:04 AM |
| head unit screws | duck | In Car Entertainment + Electronics (audio / video / alarm) | 16 | 06-29-2007 08:51 AM |
| Factory Head Unit | Kaotic Lazagna | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 05-11-2007 07:55 PM |
| Does the non integrated head unit do any processing? | ponieswhee | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 05-07-2007 09:00 PM |
| High pitched whine using stock head unit / aux input? | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 02-02-2007 12:49 PM |
