Old 08-27-2007, 02:00 PM   #1
dadi_oh
dadi_oh's Avatar
Drives: RS 4 Door Hatch
Drum Paint
I read the thread on painting calipers and drums and there are, of course, no shortage of opinions... The sign of an active forum
I want to paint my drums just to cover up the rust. Either flat or glossy black. The car is a black 06 RS 4 door hatch (I think they were only available in Canada from what I read).
I assume that the paint needs to be some sort of heat resistant paint. Any recommendations on the type to use and relative cost? I am cheap by nature so I was kinda thinkning of the flat black BBQ paint
Thanks Guys. Great Forum.
dadi_oh is offline   Reply With Quote
Old 08-27-2007, 02:03 PM   #2
nqd
Drives: 07 Yaris LB Absolute RED
fyi they have black caliper paint
v
nqd is offline   Reply With Quote
Old 08-28-2007, 10:59 PM   #3
dadi_oh
dadi_oh's Avatar
Yeah. I think that is the conclusion I have reached. I think I will brush them down with a wire brush and then treat with some rust converter (changes the rust to black and is paintable). I think Glossy Black. Might do my front calipers as well.
Thanks
06 RS 4 Door Hatch - Black
Old 08-28-2007, 11:14 PM   #4
uncleyaris
Try using the search feature, beat you too it Brick!!!
Old 08-30-2007, 12:03 PM   #5
dadi_oh
dadi_oh's Avatar
Yeah I know. I did do a search which is how I came across the discussion of pros and cons for the painting of calipers and drums. Was just soliciting further ideas. I am usually quite dilligent about researching before asking questions on the various forums to which I belong.
Toodles
Dadi Oh
Old 09-02-2007, 08:07 PM   #6
Zute
Zute's Avatar
hhhhhmmmmm, I think I shall do mine now! Thanks!
Zute is offline   Reply With Quote
Old 08-29-2007, 12:00 AM   #7
joey1320
joey1320's Avatar
Drives: Yaris LB
well the front calipers are "aluminum/silver" color, you can prob. paint them that way to keep it original and then paint the drums black.
joey1320 is offline   Reply With Quote
Old 08-29-2007, 01:00 AM   #8
Edd
Drives: None
Give them a coat of anti-rust or "kill rust" primer first, then 2-3 coats of your choice. Heat proof isn't a bad idea either.
Edd is offline   Reply With Quote
Old 08-30-2007, 12:00 PM   #9
dadi_oh
dadi_oh's Avatar
I have a bottle of something called "rust converter" that is a liquid that reacts with rust and converts it to a paintable surface. I would wire brush off the majority and then apply the rust converter and then the calliper paint I think. Not sure if I should prime it first or not. Will check the instructions on the calliper paint when I get it.
Rust is a never ending issue here in Canada since we have to use salt on the roads in the winter to melt the ice. Makes the roads safer but try spraying your car with salt all winter long and see what happens
Old 09-02-2007, 10:24 PM   #10
Edd
Drives: None
I think it's probably best to first use rust converter, then rust preventative primer, then caliper paint. Alternatively something like this might be the first two steps in one.
Old 09-02-2007, 08:26 PM   #11
kimona
kimona's Avatar
Drives: 2014 White VITZ
I presume your local Canadian Tire store should have exactly what you're looking for.
Old 09-02-2007, 08:31 PM   #12
jdium
Mr Attitude
jdium's Avatar
Drives: Blazing Blue 5 Spd
I think I'm going to paint mine camo so you can't see them then I can get open rims...
jdium is offline   Reply With Quote
Old 09-02-2007, 10:39 PM   #13
Black Yaris
der Zeck
Black Yaris's Avatar
Black painted drums FTMFW!!!
Mud Guard: To paint or not to paint Joel Leong Cosmetic Modifications (Exterior/Interior) 11 07-20-2011 04:25 AM
New 2007 Paint Condition Pavel Olavich DIY / Maintenance / Service 16 09-13-2009 04:14 PM
Buyer Beware: Huge paint defect on brand new Yaris voodoo22 General Yaris / Vitz Discussion 31 07-30-2007 08:24 PM
Yaris Paint MikeinNJ New YARIS Purchase Forum 5 05-02-2007 04:23 AM
Sissy Paint Henshin General Yaris / Vitz Discussion 13 09-01-2006 02:45 PM
