Old 08-05-2006, 11:52 AM   #1
Chaad32
Chaad32's Avatar
Drives: 2007 Liftback
Tire Question
If you change the circumfrance measurements of the tire (ie.--add bigger tires) does this change the rate at which the odometer counts?
2007 Liftback
Blazing Blue
Cold Weather, Convenience Package, Arm Rest,
Floor mats, Weathertech vent visors
Chaad32 is offline   Reply With Quote
Old 08-05-2006, 11:54 AM   #2
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Yes.
It also changes a lot more then just that...
Try this site, its very helpful. http://1010tires.com/tiresizecalcula...?action=submit
Old 08-05-2006, 12:04 PM   #3
Chaad32
Chaad32's Avatar
Thanks Chris....thats a great tool.
2007 Liftback
Blazing Blue
Old 08-05-2006, 02:55 PM   #4
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
I have been told if you are gonna chanege the diameter then its better to go rounder then smaller. I guess the smaller you go the hareder the engine has to work. Here is the calculator I use.
http://www.eunos.com/tirecalc/
Old 08-06-2006, 03:56 AM   #5
TRD_Yaris
Yarii Hunter
TRD_Yaris's Avatar
Drives: 2007 Yaris Liftback and S13's
rounder? are you using square wheels, or something?
and, yes, the overall circumfrence of the tire will affect your speedometer. Bigger tire profile means you're actually going further than your Speedo reads out, smaller tire profile will mean you're travelling slower than the speedo reads...
Thanks for all the help over the years, YarisWorld!!!
TRD_Yaris is offline   Reply With Quote
Old 08-06-2006, 09:53 AM   #6
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Drives: 09 Yaris LE, H/B, auto
Correct
If some one was to go with say 205/55-15" at 60mph (speedo) you would actually be traveling at 59
The bigger the change the bigger the difference.
However I'm sure the Toyota dealer can re calibrate the ECU for tire size just like most GM, Ford, Dodge trucks and cars
07WYarisRS is offline   Reply With Quote
tire shine casterqc Wash, Wax, Detailing, Exterior Repairs 20 11-24-2006 03:27 PM
largest tire boxerboy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 07-16-2006 08:51 PM
warranty service question faulkton New YARIS Purchase Forum 2 05-07-2006 09:23 AM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
