Old 10-31-2006, 02:40 PM   #1
sanchez
vroooom!
sanchez's Avatar
Drives: 2007 yaris liftback
run foglights only??
sup guys new here and just had a question is it possible to just have your fog lights turned on without my headlights being on i have a 2007 liftback (us) any knowledge is appreciated thanx
sanchez is offline   Reply With Quote
Old 10-31-2006, 04:55 PM   #2
DARKYARIS
Drives: 2007 Yaris RS HB
YUP....U got to ground the orange wire on the DRL harness.
Just check the other posts on DRLs
DARKYARIS is offline   Reply With Quote
Old 10-31-2006, 10:56 PM   #3
manborn
are u still 34/39?
manborn's Avatar
Drives: flint mica yaris s sedan
what if no DRLs?
manborn is offline   Reply With Quote
Old 04-07-2007, 10:38 PM   #4
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
bump I have no DRL's either...
Old 04-07-2007, 11:50 PM   #5
sf180th
Back in USA in days!
sf180th's Avatar
Drives: 07 Yaris S Sedan
Send a message via Yahoo to sf180th
It all depends I have mine wired up so that I can have them on when just my running lights are on, not the head lights. Before I had them wired so they could be turned on by themselves. it just depends on how you wire them into the fuse block, wether or not you have them running off of a switched fuse or a constant powered one, make sense?
Kazera KZ-V Silver Rims, with 215-35-18 Kumho ESCTA ASX, TRD Springs, TRD Sway Bar, Fujita CAI, Blitz R-Vit i-Color, Blitz Throttle Controller, Megan Header, 2.25 Stainless Cat back Exhuast, 50 Series Flowmaster muffler, 6000k HID.
sf180th is offline   Reply With Quote
Old 04-11-2007, 01:13 PM   #6
mygfdrivesayaris
Drives: 2006 Scion XB
what wire did you tap into for the relays switched power to run with you running lamps?
mygfdrivesayaris is offline   Reply With Quote
Old 04-11-2007, 01:49 PM   #7
sf180th
sf180th's Avatar
I didnt tap into any wires, I just used something like "Add a fuse" to hook it up directly into the fuse block, that way I wouldnt have to cut any wires, I know this isnt making a whole lot of sense so maybe if I took a picture of the fuse block that might help.
Old 04-11-2007, 02:03 PM   #8
sf180th
sf180th's Avatar
Here I took a pic, I didnt want to have to splice into any of the factory wiring so thats why I just jumped off of the fuses.
Old 09-21-2007, 07:09 AM   #9
manborn
are u still 34/39?
manborn's Avatar
w/c fuse numbers are those exactly coz i want to turn my fogs switch on and actually have the bulbs light up with just the side markers (orange lights the can come on before the headlights)
thanks!
Old 09-21-2007, 07:24 AM   #10
lifthard1
Drives: Black LB
Check this out from one of the DYI this way you can also run the fogs with just the ignition on you dont have to have any lights on .Easy to do also no tapping into other wires or fuses
http://www.yarisworld.com/forums/sho...?t=3471&page=8
lifthard1 is offline   Reply With Quote
Old 09-21-2007, 03:15 PM   #11
aca72
aca72's Avatar
Drives: '07 Yaris S Sedan M5
Question
Sounds doable...
Please provide detailed DIY on your set up. I also want to run my fogs independently from the headlight switch. How do you "jumped off of the fuses"?
Sorry, I don't know much about car electricals. Thanks!
aca72 is offline   Reply With Quote
Old 04-11-2007, 02:24 PM   #12
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
I did something similar to that but instead of the fuse, it goes to the grey wire off the cingarette lighter, I squeezed it in there heheh and my fog switch is always on. I run them every hour of the day.
-- Blen
Old 09-21-2007, 10:24 AM   #13
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
i have no drl as well(removed) and my fogs are setup to run without headlights......
Old 09-21-2007, 01:43 PM   #14
caveatipse
Drives: 2007 Black Yaris
Is it legal, though, to drive at night with just fog lights?
caveatipse is offline   Reply With Quote
Old 09-21-2007, 01:44 PM   #15
Astroman
Modded Moderator
Astroman's Avatar
I know it isn't in WA state, but I don't think that will be a problem for you.
Old 09-21-2007, 01:55 PM   #16
lifthard1
Drives: Black LB
Not legal in Alabama
Old 09-21-2007, 05:39 PM   #17
Black Yaris
der Zeck
Black Yaris's Avatar
here I did mine a lil nicer.... and mine is for a LB
my fogs can be turned on or off any time the ignition is on, and will automatily turn off with the ignition
Old 09-21-2007, 05:50 PM   #18
aca72
aca72's Avatar
I've analyzed that setup many times and I'm still bummed. Pardon my ignorance, is that wiring applicable for the Yaris S sedans that came with factory fog lamps?
run flat tires? stuffy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 12-01-2012 10:35 PM
where to run amp positive cable??? punch In Car Entertainment + Electronics (audio / video / alarm) 8 12-21-2006 07:50 PM
To those with amps in your trunk/rear... vodkalush In Car Entertainment + Electronics (audio / video / alarm) 9 10-03-2006 06:34 AM
Harman Kardon Drive + Play for IPOD sroberts In Car Entertainment + Electronics (audio / video / alarm) 5 07-01-2006 01:05 PM
Will putting new lowering springs damage original shock absorbers in the long run? Joel Leong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 06-07-2006 08:30 AM
