Old 10-26-2008, 12:44 PM   #1
Smokey159
Drives: Yaris Liftback
HELP? Anyone know if this will work?
I'm putting Tein S-Techs on my liftback. It's a 1.9" drop front and rear.
I'm looking at some 17" wheels that have 205/40/17 tires mounted on them. The offset of the wheels are 42mm.
1) Will these rub?
2) Will this work in terms of the speedo still being right?
Thanks folks.
Smokey159 is offline   Reply With Quote
Old 10-26-2008, 01:05 PM   #2
Phaeton
Phaeton's Avatar
Drives: Blazing Blue Liftback
I think you will be just fine I've seen alot of people using similar set up.
Old 10-26-2008, 03:35 PM   #3
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
i heard they do when hitting bumps but other then that there fine. speedo needs to be recalibrated. you also might notice that your mpg are less once you put 17"s on depending the weight and how much over stock wheel weight they are but if the weight less then stock then you should be fine
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 10-26-2008, 10:42 PM   #4
saspy
Drives: Toyota Yaris
17"7 +42 and a 1"9 drop will rub. because i have df210 17"7+42 the drop is only 1"6 barely clears
saspy is offline   Reply With Quote
Old 10-27-2008, 09:20 AM   #5
Smokey159
LOL, ok.
1 - no rub
1 - rub on bumps
1 - Will definately rub.
Keep the opinions coming folks... maybe I should make this a poll...
Old 10-27-2008, 04:53 PM   #6
MUSKOKA800
MUSKOKA800's Avatar
Originally Posted by Smokey159 View Post
LOL, ok.
1 - no rub
1 - rub on bumps
Roll the dice!
Old 10-28-2008, 12:51 AM   #7
kimona
kimona's Avatar
Drives: 2014 White VITZ
Originally Posted by MUSKOKA800 View Post
Roll the dice!
Well, it is a crap shoot to some extent. Every application is different.
Not all offsets are accurate. 205mm tyres actually vary in width quite a bit among brands and even across brands.
Plus, every Yaris is unique... built within acceptable tolerances, so what rubs on one Yaris may not rub on another. In fact, you may be fine on the left front and rub on the right front!
Generally speaking, a mild to moderate drop with 205 rubber on 7" wheels, ET42-45, won't rub or may rub under certain conditions, but not seriously.
Old 10-28-2008, 05:26 AM   #8
ddongbap
I'll add this. It will rub, It'll rub on bumps, AND It would not rub. haha.
Anyways, your speedo would be off by 1.2 percent. Meaning at 100MPH, you're actually doing 98.8MPH, and at 60mph you're going to be going an actual 59.3mph.
Old 10-28-2008, 08:57 PM   #9
paradigm
o.O
paradigm's Avatar
Drives: 8
i ran the same for a little bit, only rubbed on good size dips. normal driving is ok.
paradigm is offline   Reply With Quote
15 inch WORK XSA autofashionfred Items for Sale by private party 15 10-21-2008 02:51 AM
Do you use forum at work or home or both ? Julz Off-topic / Other Cars / Everything else Discussions 27 09-11-2007 05:54 PM
Will this work? umm_bacon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 09-10-2007 10:16 AM
My Work, Your Work - Stories and Fun SmallCarGuy Off-topic / Other Cars / Everything else Discussions 0 09-02-2007 08:43 PM
Anyone in So Cal needs work on their Yaris Bdaslug California 24 08-26-2007 06:10 AM
