Old 07-29-2006, 05:39 AM   #1
bulldogs2k
bulldogs2k's Avatar
Drives: '00 s2000, 2007 yaris hatch
Gears for s2000
I need to ask you all a question. Its in regards to my s2000 and a different gear ratio/final drive. Basically, I have two choices in ratios. 4.57r or 4.77s. The difference between the two are pretty noticable while cruising in highway speeds and acelleration. The 4.77s will keep my car reving pretty high, yet it will provide excellent acceleration. My car with a intake, exhaust and 4.77s will put me in the low 13's to 13.6 on the quarter mile. For refference, those times are as good as a s/c s2000. The 4.57s on the other hand is a little more "watered" down, but it has the best of both worlds," Performance increase while maintaining drivability." It will provide me with an increase in acceleration, but not as quick as the 4.77s. Both will decrease my top end speed, which does not bother me. I want to hear from you guys!
Thanks,
Angelo
Btw, I plan on autox's and taking it to the strip every so often.
bulldogs2k is offline   Reply With Quote
Old 07-29-2006, 02:08 PM   #2
AE86Yaris
Drives: 85 AE86/blazing blue 07
well i have 4.77 gears in my "race car" up from stock 4.31, and since i won't be driving daily for very long the 4k cruising on the freeway is fine for now (still get 30mpg :)), but if i had the choice to get another ratio again i would have gotten the TRD 5.1 gears and then save up for the TRD gear set too, in preperation for TODA 296/288 cams.
so i say 4.77 or nothing, you have the yaris to save you gas
AE86Yaris is offline   Reply With Quote
Old 07-29-2006, 04:19 PM   #3
Moose
Resident Redneck
Moose's Avatar
Drives: 07 Polar White Yaris Sedan 5M
+1
Expect much less than 20mpg with 4.77's in an S2000.
Go Toda ITBs or go home!
My other rides:
2003 Honda Civic LX Coupe 5M- S/C K24 w/ LSD coming soon!
1999 Honda Civic EX Coupe 5M w/ B18 powaa
1985 Toyota Celica GTS Coupe 5M- track whip
http://www.importlounge.com
Moose is offline   Reply With Quote
Old 07-29-2006, 08:21 PM   #4
bulldogs2k
bulldogs2k's Avatar
mmmm....ITBs! i dont think i have enough money for those, not yet anyways.
Old 07-30-2006, 02:48 AM   #5
bulldogs2k
bulldogs2k's Avatar
the s2k guys are saying the 4.57s are better 1/4 mile wise due to less shifting from the 4.77s. So confused!!!!
Old 08-08-2006, 05:32 AM   #6
jmew0ng
Drives: Scion FRS
maybe say you won't have to shift into 5th gear or 4th gear when you hit the end of the stretch?? shifts for some people cost a good amount of time from their 1/4 mile time
That's the only thing I could think of for them saying less shifting.
jmew0ng is offline   Reply With Quote
Old 08-08-2006, 12:46 PM   #7
bulldogs2k
bulldogs2k's Avatar
after reading more into it, that is exactly what is happening. S2000 with 4.77s run out of steam just before the end of the track. I may go for the 4.57s, which will leave me room to upgrade to a supercharger. although, i had my first ride in a turbo s2k and that had a little kick to it.... I would go turbo but the only thing holding me back is the smog testing.
A
Old 08-09-2006, 02:41 AM   #8
TRD_Yaris
Yarii Hunter
TRD_Yaris's Avatar
Drives: 2007 Yaris Liftback and S13's
can you just change out your 6th gear (final drive gear, correct?)? This would give you MUCH better highway fuel efficiency and one SWEET top end speed!! This is REALLY common on the honda cars, especially Integras with Type R or civic Si transmissions. It's hard to say on a "street" car because there is way too many conditions/situations to take into account.
Are you on Honda-Tech.com...i'm guessing they might be a LITTLe more informed, not because it's specifically a Honda but because there are 10,000+ people who post on "gearing" on a regular basis. Honda-tech.com use to be one of the LARGEST Message Boards on the internet, like #8 or something..
Thanks for all the help over the years, YarisWorld!!!
TRD_Yaris is offline   Reply With Quote
Old 08-09-2006, 11:53 AM   #9
bulldogs2k
bulldogs2k's Avatar
I am a member at s2ki.com. i'll try out honda-tech.com and do some searching.
thanks.
A
Gears bulldogs2k Performance Modifications 17 07-26-2006 08:16 PM
