![]() Drives: 2008 Join Date: Sep 2013
Anyone install a Hatch lock plunger?
I just got this 08 lift back, and love the little car.
One thing that I am struggling with is the lack of a lock plunger for the hatch. Am I missing something or is the only way to lock/unlock the hatch is w/ the key? I had an old 3 door civic before and it had a little plunger w/ an orange ring on it, so you could 1, visually verify the hatch’s locked status 2, lock the hatch before you closed it w/o the key anyone done a mod for this, I haven’t taken it apart too much, but I did pop the little cover off and found there is something in there I can move to lock/unlock it. Just need to extend that up to the top and install a plunger of some sort. Thanks |
It sounds like your car does not have power locks. You can add the power lock actuator from one with power locks. The other option is to switch the whole hatch lock assembly to a Scion IQ hatch switch. I have done that on with my 09, which had power locks, and my 08, which I upgraded to power locks. With my Scion IQ switch system the hatch switch is automatically disabled when the doors are locked and active when they are unlocked.
http://www.yarisworld.com/forums/showthread.php?t=39677
Thanks Scott,
correct, I do not have power locks Slick system you have on yours, |
so, your best bet would be to start with adding power locks. An aftermarket kit, like the one I used on my Red one, can be had for under $150 (including keyless entry) from a place like a1-electric.com. OEM Hatch lock actuators can be found for around $50 or you can go with something like my IQ mod.
I actually ran my echo hatch with the cover off.. as it wasn't covering much anyways. So i always simply put my hand and flip the switch to lock the hatch. LOL
If i wanted to know if the hatch was locked? Try to open it. |
![]() Drives: 2011 Yaris 3dr Join Date: May 2013
CTScott, does your IQ actuator mod work with the factory keyless entry? Is there any other keyless entry module from another Toyota that has the remote hatch open function that could be swapped in?
My mod would work fine with an OEM keyless entry equipped Yaris. You wouldn't have the pop functionality, since the Yaris remote doesn't have a separate hatch button, but the lock and unlock would work correctly. A module from another vehicle wouldn't help, as the Yaris Body ECU communicates with the keyless receiver and the Yaris one would not support the additional function.
#8 | |
I would have to do something creative, like have my module look for a double or triple press of the unlock to signal a hatch pop.
| Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 08:47 AM |
| Power upgrade (pictures). | W.A.S.P | DIY / Maintenance / Service | 91 | 11-15-2017 10:32 PM |
| Yaris Hatch Purchase | warlock | New YARIS Purchase Forum | 7 | 09-02-2007 11:59 PM |
| Power hatch lock? | paultyler_82 | DIY / Maintenance / Service | 5 | 09-08-2006 01:15 AM |
