Old 12-11-2008, 07:42 PM   #1
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
Tracking/Racing/Auto-X regulars - What's broken so far?
I'm just thinking that the Yarii that regularly take part in closed-course events would likely be driven harder than your typical Yaris that does the occasional traffic light sprint.
Therefore I'm curious to know what's broken or worn out on your car so far, and at what mileage it happened at.
For me, I found that track days are highly detrimental to tire longevity, but that's a simple wear and tear issue.
I suffered a 2nd to 3rd gear gearbox syncromesh failure at around 25000mi though.
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 12-11-2008, 07:48 PM   #2
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
I'm at over 18k miles and have seen plenty of track time and autocross in the 8 months that I've owned the car.
So far, tires and brake pads, of course. Which I don't consider "breakage", that's just motorsports consumables. The only "problem" I've had has been a high-rpm misfire at Sebring which was cured by replacing the spark plugs with a set of good ol' NGK's.
Old 12-11-2008, 08:31 PM   #3
jkuchta
Drives: 2007 Yaris hatch (red)
I've had no problems so far, with 40,000+ miles and two trackdays under the Yaris' belt. I've only seen oil temps above 109 Degrees C once on the track, and on the street I only see 80-90 degrees C.
This car eats tires, esspecially with the factory camber settings. A few degrees negative should help the situation, though.
jkuchta is offline   Reply With Quote
Old 12-11-2008, 09:05 PM   #4
seth_man
seth_man's Avatar
Drives: 08 Liftback
21K miles, track time, stiff coilover springs and so far nothing has broken and no odd noises.
seth_man is offline   Reply With Quote
Old 12-11-2008, 09:13 PM   #5
thepoche
thepoche's Avatar
Drives: Toyota Yaris CE
After 4 track days, only thing that went wrong is brake pedal travel. Even after installing stainless brake lines and good brake fluid, the travel on the pedal is way more than stock.
thepoche is offline   Reply With Quote
Old 12-12-2008, 01:00 AM   #6
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Sounds like you have an air bubble somewhere.
You need to bleed your brakes, and maybe the master cylinder. If you have ABS and you got an air bubble down in the ABS module you will probably have to take it to the dealer.
Old 12-12-2008, 01:22 AM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
get brake fluid that boils at a higher temperature as well.
70,000 miles, more autocrosses than i can remember, coming up on 5 years..
what's been replaced:
front brake pads
stock clutch (at 10,000 miles.. it wasn't worn out, burned, scored or anything.. it was just too weak.. the Spec stg3 has the other 60,000miles on it)
one wheel stud (rear of the car, installer error)
more sets of Hoosiers than i want to think about it
what needs to be replaced:
swaybar endlinks
steering tierod endlinks (when the car is on R comps, you feel a very slight pop when you wiggle the wheel left/right)
brake pads again (i have Project mU pads now.. i'm gonna go back to OEM toyotas)
what has broken:
an engine
a transmission
4 sets of shift cables
3 bumpers
1 set of racing harnesses (they were out of spec)
i know this is all xA info, just thought i'd show you guys what you'll be looking at in your future of autocross/trackdays
Old 12-26-2008, 12:10 AM   #8
YarisSedan
Drives: 08 Yaris Sedan
Yeah sounds like you got your brake fluid hot enough that it started to boil over and possibly air got into your abs system. YOu can put on a new master cylinder replaced your lines brake pads and bleed the system all you want. Nothing you can do to get the pedal back to the way it was without hooking a scanner to the computer and command the abs system to bleed itself out. Then manually bleed the lines after. Have to take it to a shop with a manufacture specific scanner to do it.
Old 12-12-2008, 01:25 AM   #9
mojoyaris
Ecurie Snoopy Lives
mojoyaris's Avatar
Drives: Jojo
Besides tire wear, brake fluid and pads
Almost a dozen track days, Solo sprint events and lots of Autocross.
The most wear on the car was the body kit where a co driver at one of the regional events cracked my brand new front end.
The engines overheated, radiator gets hot and brakes glow orange, but the clutch is still solid.
This is one tough little car!!
Sponsors and Organizations:
Toyota Rally Canada
Yokohama Tire Canada
Western Canada Rally Association
Ecurie (Team) Snoopy Canada, racing since 1966
mojoyaris is offline   Reply With Quote
Old 12-12-2008, 04:20 AM   #10
cleong
cleong's Avatar
My mechanical concerns as I go into the next round of track sessions is,
Engine mounts
Driveshafts
Suspension bushes
Clutch
Gearbox syncromesh fault reoccuring
I'm glad to see no one brought these issues up yet. But then again, no one broke their gear syncros when I did!
TRD Blue brake pads
DC Sports header
Old 12-12-2008, 06:43 AM   #11
2 track days and i havent broken anything. tires (which are high performance all seasons - - fuzion hri's) show signs of being heated up really hot (minor chunking), but thats it...
Old 12-25-2008, 02:40 PM   #12
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
I am stuck with the automatic transmission. Should I just stay away from track days and just stick to autocross?
Specifically, is the AT sturdy enough?
Old 12-25-2008, 03:44 PM   #13
Tamago
Tamago's Avatar
Drives: UZJ100
add a transmission and a set of axles to my above broken list lol
Old 12-25-2008, 09:12 PM   #14
damn
that from auto-x or running boosted?
Old 12-26-2008, 07:46 AM   #15
Tamago
Tamago's Avatar
Drives: UZJ100
damn
combination of both i'd say..
Old 12-27-2008, 04:47 AM   #16
WolfWings
WolfWings's Avatar
I'll add another set of syncro's here, 1st and 2nd are rough to shift into without noticable grinding, after about five sessions worth of autocrossing. (Three times solo, one time with a co-driver hot-swapping so the system just never had a chance to cool down between runs.) I'm just over 30k miles though, gonna take it into the dealership in a day or four since changing the tranny oil didn't improve matters any.
Old 12-27-2008, 09:21 AM   #17
Tamago
Tamago's Avatar
Drives: UZJ100
what did you use for gear oil?
Old 01-17-2009, 12:35 PM   #18
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
I have done several track days . One really sticks out . I drove 3 hours to Savanah GA . Then did 120 + consecutive laps . Then back 3 hours . I love the Yaris .
I've only had to replace tires( 5 sets) , pads( 3 sets) and rotors(2 sets). I have 67 K on mine so far .
Broken windshield mikeukrainetz General Yaris / Vitz Discussion 17 07-19-2007 07:04 AM
Horn broken, watch for finger RogueYaris General Yaris / Vitz Discussion 11 06-26-2007 10:16 PM
o nos, my imac is broken :'( Blenjar Off-topic / Other Cars / Everything else Discussions 3 06-17-2007 06:21 PM
Broken hatch window Bayou Blue Canada 4 01-26-2007 11:01 AM
yaris got broken in! bulldogs2k General Yaris / Vitz Discussion 15 10-02-2006 12:43 AM
