Old 12-19-2008, 04:01 PM   #1
puetato89
Just call me Ray, better?
puetato89's Avatar
Drives: 08 Yaris
foglight seperation
does any one know how to make it to where you can seperately turn on the fogs without turning on the head lights??
Old 12-19-2008, 04:04 PM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
i can send you a wiring diagram to fix it but you'll have to do a little wiring wizardry
Old 12-19-2008, 04:08 PM   #3
puetato89
puetato89's Avatar
Drives: 08 Yaris
sweet... and its ok ive delt with worse
Old 12-19-2008, 04:12 PM   #4
Tamago
Tamago's Avatar
Drives: ZZW30
you'll need to move the signal wire (input) from the headlight circuit to either an ignition signal (recommended) or a battery signal (not recommended)..
Old 12-19-2008, 05:39 PM   #5
IllusionX
Drives: 07 Yaris Sedan Aero
if you have DRL. ground the orange wire from the module.
Old 12-19-2008, 10:20 PM   #6
puetato89
puetato89's Avatar
Drives: 08 Yaris
thanx for the input guys
Old 12-19-2008, 10:55 PM   #7
Mine are on a switch and on the ignition, so basically they are always on when I start the car and off when the car is off.
Those things suck juice, and I've run my battery down before, so that is why I wired them this way - I can't screw up.
Old 12-19-2008, 11:00 PM   #8
puetato89
puetato89's Avatar
Drives: 08 Yaris
lol nice one garm... maybe when i got to cali you can help me with it??... (if my car gets fixed)
Old 12-20-2008, 11:29 AM   #9
IllusionX
I was thinking about making a relay, and using the hand brake switch to allow them to be on or not. Kinda makes the OEM DRL.
LB yellow foglight set nerd_vitZ Items for Sale by private party 10 12-11-2008 07:53 AM
2009 foglight kits? songa Cosmetic Modifications (Exterior/Interior) 3 12-10-2008 12:58 PM
Foglight Switch natethegreat38 Cosmetic Modifications (Exterior/Interior) 2 10-24-2008 01:42 PM
Foglight housing and glass get hotter than Hell!!! razzorjet2 DIY / Maintenance / Service 3 05-01-2007 10:48 PM
OEM Foglight Red Wire Controversy razzorjet2 DIY / Maintenance / Service 5 04-18-2007 09:01 AM
