![]() Drives: 07 sedan-flint mica, 96VFR750 Join Date: May 2006
Decided to upgrade stereo
Ok so I bought and Yaris and stereo needed to be upgraded. I just sold my 2000 Ford Focus ZX3 which had 170,000 miles but I kept its Alpine headunit and subwoofer box which will go into the Yaris.
Following are pictures of progress: front door speakers which are riveted on head unit |
Here is a picture with all the panels off and a trial placement of the Alpine headunit. The closest trim kit I could find is from Metra for the Echo/Celica. I also needed an antenna adapter.
![]() ![]() ![]() Drives: S Flint Mica Join Date: May 2006
Pretty cool! I was wondering how difficult it would be to replace the HU seeing that the current faceplate is huge. I don't mind the stock system but might upgrade when I get more $$. Let us know how long it took you to install once you have everything done.
Kevin |
![]() ![]() ![]() ![]() Drives: 2007 Yaris Sedan "D" package Join Date: May 2006
Umm in the future your to drill out rivets, not pry at them!!!
can't wait to see the finished install.. |
#5 | |
![]() Drives: 2007 Liftback Join Date: May 2006
Good work, thanks for the pics. New speakers for the Yaris.
Gonna swap out my aftermarket stuff from my Maxima. |
spase peepole
Drives: BLAZING BLUE Liftback 5 Speed Join Date: Apr 2006
Great pics!
I was curious as to how difficult it would be to replace the speaks/head unit. Judging from the pics it doesn't look to hard, for a newb like myself, aside from drilling out the rivets. Be sure to post pics of the new speaks when you get a chance. |
![]() ![]() Drives: 2007 Yaris RS Silver Join Date: May 2006
cool, but don't you need those plastic speaker frames to hold your new speakers to the door?? looks like ya snaped one.? and do you have to buy that antena adapter cable for every aftermarket deck?
#9 | |
![]() ![]() ![]() Drives: 2007 3 dr manual Join Date: Apr 2006
thanks for posting the exact kit you used for the deck
Following is the bracket screwed on. I forgot to take a picture of the speaker on before placing back the door panels. (a passing rainstorm rushed me) Anyways, the Alpine head unit is on.
Next project is to connect the subwoofer. |
Around the universe...
Drives: Uber-Evolved Pokemon Join Date: Jan 2006
I guess the sedan needs an antenna adapter....On my hatchback, the antenna plugged directly into my Clarion deck with no extra adapter necessary...
Cheers |
I finished hooking up the subwoofer box. I ran the amp power wire through a hole in the firewall in the passenger side just under the floormat. Then ran the wires under the right moldings towards the back into the area behind the backseat. I still have plenty of room in the trunk.
#14 |
There's no noticeable noise at all.
#15 |
swappin cogs
Jai You da man!! Thanks for the pics and info. I've done business with Crutchfield in the past and found them to be really helpful. I'll bet they would like to see your pics as part of thier research for the Yaris.
#16 |
Have you done the rear sedan speakers yet? are they a simple 6x9 swap, are brackets needed thanks
stocking up on parts now... |
#17 |
![]() ![]() Drives: 07 Yaris S Type Join Date: May 2006
Rear 6X9s are straight forward. After taking off the rear deck, four 10mm bolts hold each factory speaker. You'll have to drill your own bolt holes, the factory speaker bolt pattern are wider. Depth is not an issue at all.
#18 |
[QUOTE=Sp33dY]Are they 10s or 12s" Polk Audios? You have a sedan, right?
This is where the parts came from http://www.cardomain.com/ride/359220 I'm gonna miss the Focus
| Stereo Upgrades....what to do!? | gravylegs | In Car Entertainment + Electronics (audio / video / alarm) | 39 | 02-28-2010 12:58 PM |
| Security upgrade | Ryu | General Yaris / Vitz Discussion | 7 | 05-09-2006 09:00 PM |
| security upgrade? | got615 | General Yaris / Vitz Discussion | 4 | 04-27-2006 09:50 AM |
| aftermarket stereo kit? | xCookiE | General Yaris / Vitz Discussion | 4 | 02-16-2006 10:33 PM |
| Factory Stereo and Audio | kralmrax | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 01-14-2006 01:06 AM |
