![]() ![]() Drives: 2008 Copper Orange LE HB Join Date: Oct 2008
Had my 1st Toyota Maintenance...
Went in for my scheduled maintenance yesterday. Had a squeak in my brakes for quite awhile so I asked the dealership to look at them. Well it doesn't squeak anymore but the emergency parking brake is very hard to lift up. Has anyone else experienced this. We use our E-brake a lot when parking the car, so this is somewhat annoying...I liked the way it was before.
The YARIS is the REAL Smart car ! |
#2 | |
#3 | |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
#4 | |
dont' feed the noob misinformation.
What?
Drives: 2007 Yaris LB Join Date: Nov 2008
When you lift the handbrake, how many clicks before you can't lift it any more? That is how the handbrake adjustment spec is measured.
#6 | ||
Go "properly adjust" yours until you almost can't lift your handbrake enough to get it to click once or twice...yeah, got it too tight didn't you?
#7 | |
adjust the drums til they drag (no resistance, you can just hear them) , then back off the cable adjustment half a turn. if you can't pull the e-brake handle up enough to keep the car from moving (be it 1 click or 10) then you need to start doing arm excercises. carrot top jack up one of your rear wheels, and with the e-brake OFF, see if the wheel spins freely with no drag or noise.
What?
"Very hard to lift up" is subjective. You don't know the extent of the OP's experience or what they're comparing it to. Perhaps the brake was very loose before and went up 15 clicks before grabbing, and now it's within spec... which would make it seem "very hard to lift" more than about half of what it used to.
You're making assumptions about what the OP meant by what they said. You can't do that. Ask more questions. Get a clear understanding of the problem before pronouncing a diagnosis. |
#9 | |
When I replace brakes, I start by using of a drum gauge, and then adjust until I can just start to hear scraping. I don't run across too many stretched cables. 1 click is too tight, 10 clicks is a Ford Tempo in serious need of a brake job. |
#10 | |
#11 | |
did you miss the part where i told the OP to jack up the car and check for drag?
#12 | |
This is just getting silly. OP, don't let any of us assume anything. Have dealer check out your concerns. Better to have it rechecked than to just assume that you're weak and it's perfect and have you to just keep driving it with a possible problem with the brake adjustment. |
When I last took my car in November. They adjusted my drums. My car felt like it stopped faster/didn't drop as much in the front, it was nice. I don't think my fuel economy dropped, I forgot to be honest.
I was able to put it into 1 click, and it would stop the car from moving. Now, I have to pick it up to I dont know how many clicks, and on a hill, the drums make a bad noise as if they slip, any time weight it added or removed from the car, or the high is too much. I feel now as if they are not stopping the car as easily. Oh, and if I try using them while the car is moving, it doesn't do much, especially comparing them to back in November. I know in my dads car I can pick it up 3 or 4 clicks and the tires will lock. In the yaris, that will never happen and I don't know why. How can I adjust my drums myself?(ebrake level) |
#14 |
What?
The assumption that a newb on a forum like this one doesn't know much is usually a pretty safe bet. But, you can ask questions without making them looks dumb. And that keeps you from making incorrect assumptions about their problem.
#15 | |
My brakes feel great, and 5 clicks on my handbrake. On my inclined (average, I assume) driveway it's 5 clicks and it's never tried to roll forward or reverse. I've never adjusted them, btw. |
#16 | |
therefore, number of posts or join date have nothing to do with it. i'll wager that many of the 1000plus posters on YW don't even change their own oil. which makes them noobs. ;)
#17 | |
Leaving this thread before I get sucked in any worse =o
![]() 1997 Lincoln Town Car - SOLD 2008 Scion xD (w/ automatic) - SOLD 2008 Yaris HB - SOLD Last edited by 1stToyota; 04-28-2009 at 12:14 PM. |
#18 |
| Toyota Maintenance at Dealership? | fmicle | DIY / Maintenance / Service | 18 | 03-17-2012 11:27 AM |
| Response from Toyota on my special order | drdavidr4u | New YARIS Purchase Forum | 14 | 04-27-2010 08:59 PM |
| Response from Toyota | Driver | New YARIS Purchase Forum | 22 | 09-04-2006 07:44 PM |
| Toyota Delays | Buckethead | General Yaris / Vitz Discussion | 3 | 08-26-2006 03:16 AM |
| Toyota Yaris to Sponsor FOX's "Prison Break" | YarisBueller | General Yaris / Vitz Discussion | 0 | 04-30-2006 08:01 PM |
