Old 01-18-2009, 09:26 AM   #1
dinamix
Drives: magntic grey
steering wheel outta control when im coming to a stop
i just switched over to 205/15/50 from stock
everytime i slowly come to a stop at a crowned intersection its seems like my steering wheel has a mind of its own. the stock wheels felt alot softer and more on control.
will the wider tider affect my suspension in the long run? should i switch to 195 or will 205's be ok.>? i wanna keep my rims what can do fix this?
btw im planning to lower around 1.5 inches later on. i suspect its gonna get worse.
dinamix is offline   Reply With Quote
Old 01-18-2009, 09:32 AM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
What tire did you go with?
Originally Posted by xnamerxx
you nailed it sir.
Old 01-18-2009, 09:41 AM   #3
dinamix
205/50/15 on 15x7 alloys
Old 01-18-2009, 10:27 AM   #4
I think he also means, what brand and model?
Also, I noticed the power steering can do some weird antics if the pavement is not so smooth, is that the case?
Old 01-18-2009, 10:39 AM   #5
i found similar things on my XRS when i had 235 tires on it....it would track the grooves in the road a bit more....
youll be ok w/ 205's you just need to compensate more because of it when the road isnt so smooth
Old 01-18-2009, 11:05 AM   #6
kimona
kimona's Avatar
Drives: 2014 White VITZ
205mm tyres are a great fitment for our cars. No worries there. But, occasionally it's just the tyre's tread design that makes the car do squirrelly things. What tyres are you running?
Old 01-18-2009, 11:16 AM   #7
Danish Yaris
Drives: Toyota Yaris 1,8 TS 5dr. 2007
Hi
When the tyres are wider and the profile is lower you will get a more direct feeling. Especially if it´s a very hard tire you are using. Did you try to squeez the tyres before they were mounted on the rims?
Regards Steven.
Danish Yaris is offline   Reply With Quote
Mesh Steering Wheel Cover... Toxic? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 20 07-03-2010 06:53 AM
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 01:05 AM
audio volume control on steering wheel hans_fh In Car Entertainment + Electronics (audio / video / alarm) 18 01-04-2009 10:07 PM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 07:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 02:05 AM
