Old 01-25-2009, 12:46 PM   #1
GreenSpeed
Drives: '08 Yaris LB
Rear Latch/Lock Woes
I was working this morning on adding an LED bulb to my rear hatch area and wanted to find the switch to turn the light off while I was taking the side rear panel off.
Like a dumb-ass, I starting messing around with the latch/lock on the bottom side of the rear door and accidentally turned the plastic locking mechanism to lock. Now, obviously the door won't close because it's being blocked by the stupid plastic piece.
Does this make sense and can someone please tell me how to reset the latch back to its original position?
Appreciated!
GreenSpeed is offline   Reply With Quote
Old 01-25-2009, 01:26 PM   #2
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Insert key from outside the door and unlock it?
Old 01-25-2009, 01:50 PM   #3
GreenSpeed
I'll give that a try. I tried to lock and unlock using my keyless fob without success, but your suggestion sounds like a better solution. True blonde moment on my part.
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
rear fog light and tuned rear lights lefti696 Cosmetic Modifications (Exterior/Interior) 0 11-09-2006 03:06 PM
