Train317
Drives: 2008 Toyota Yaris S Sedan Join Date: Nov 2008
XXR Sportmax 513 Wheels and Tires
I'm convinced that I am going to buy the XXR 513s in gun metal gray for my 2008, silver sedan S. My sedan is lowered on Tanabe DF 210s. I would like to go up a rim size and put on 16 x 7s. My question is what would be the best offset for the rims and what size tire would help me avoid any problems with rubbing? Also, I am open to a tire brand/model. I live in Michigan and would be running this set up from spring through fall only. I use the car for commuting. Any help/suggestions would be much appreciated!
"Show me a person who has never made a mistake and I'll show you someone who has never achieved much"
Train317
OK..so 0 and 15 are out...I see that alot when this rim is advertised.
toyota
+40 with 195/50/16 , +42 and up 205 will do without rubbing.. rear i believe you can get away with +30 offset on 205's.. but i could be wrong.
![]() ![]() ![]() ![]() Drives: Soon to be LFA Join Date: Oct 2008
those would look awesome on my Aw11
Train317
Ok.. so around +40 for the rims would be ideal?
Train317
195/50/16 woudl be good for tires? Would that be taller, same or shorter than stock do you know?
toyota
the same the stock rs, the stock is actually .1 inch bigger which is almost nothing..unless you got base model which uses smaller diameter wheels then this setup is a lot bigger.
![]() ![]() ![]() ![]() Drives: 2008 Yaris RS 4-Door LB Join Date: Oct 2008
I run a 17 x 7 +40 offset wheels with 205/40 x 17 tires on my Yaris 4-door LB. Car is also lowered with Eibach Pro-Kit springs. Absolutely no rubbing issues.
Hope this helps. Good luck.
Benggolf2 |
Train317
Thanks for the info Marcus and Benggolf 2...wow your car looks very, very tastefully done. Thanks for all the info thus far. From my research it doesn't look like enough offset is offered on a 513....I did find a similar wheel...ROTA RB...it comes in either a 40 or 42 offset among others. Now I just need to find a place that sells them and wouldn't mind getting tires from the same. Would need it shipped to Michigan. Any ideas on where to buy. Most of the really big tire/wheel distributors don't seem to carry ROTAs....
#10 | |
BTW train317, I have +10mm H&R wheel spacers at the rear to bring the tires almost flush to the body work (no rubbing whatsoever). You might want to consider doing the same.
Benggolf2 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
Let me throw in that I run a 17x7 +42 offset wheel and I do rub (on DF210's), so I would go for the +40 offset that Benggolf2 uses and has no issues with.
#12 | |
DF210 lower the car more than Pro-Kit springs. Ryank, you car looks lower than mine in the photos.
Benggolf2 |
Train317
Thanks for all the good info. BengGolf 2 did you have to go with longer wheel studs when you put on the rear spacers?
#14 | |
Benggolf2 |
#15 |
Train317
Excellent thanks for the info!
#16 |
toyota
#17 |
![]() ![]() ![]() Drives: '07 Yaris Sedan/'03 Protege Join Date: Oct 2008
| Original (almost new) Yaris wheels / tires | kennywhy | Items for Sale by private party | 3 | 08-28-2009 12:27 PM |
| OE wheels + tires question | Tonavi | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 03-05-2009 10:35 PM |
| FS: Rays Wheels and Tires | spechuy | Items for Sale by private party | 10 | 11-07-2008 09:37 AM |
| Keep tires on stock wheels? | LtNoogie | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 10-31-2008 10:00 PM |
| Factory base wheels & tires for Liftback | kennywhy | Items for Sale by private party | 6 | 01-22-2007 06:31 AM |
