Old 02-24-2009, 08:10 AM   #1
goku87
goku87's Avatar
Drives: Black HB
Question Disconnecting battery to work on electrical system
Does it really matter which terminal you disconnect whenever you are installing stuff? I've always disconnected the + but only recently for some reason I keep noticing everywhere that you should disconnect the -? Does it really matter?
goku87 is offline   Reply With Quote
Old 02-24-2009, 08:16 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
EDIT: either connection is fine.
What are you working on that you must disconnect the battery ? The dealer didn't even disconnect mine when they replaced the alternator.
Old 02-24-2009, 08:23 AM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by IllusionX View Post
disconnect the + on the yaris. The + is constant everywhere in the car and the ground is switched. So disconnecting an unconnected ground do no justice.
lmfao disconnect whichever one is accessible, it does the same thing
don't listen to this guy
Old 02-24-2009, 08:23 AM   #4
goku87
goku87's Avatar
Drives: Black HB
Just a couple amps. I disconnect the battery because no matter how many systems I install, I have a bad habit of letting my live wires touch things they shouldnt. :)
Old 02-24-2009, 10:15 AM   #5
IllusionX
I guess you shouldn't connect your live wire before you connect it to the amp.
Old 02-24-2009, 10:12 AM   #6
IllusionX
You are right one this one... i completely forgot about how the battery is connected to the car LOL.
edited my post...
Old 03-28-2009, 08:40 PM   #7
Uncle Yaris
Drives: 2008 Yaris 5-door
Yes, it matters. If you disconnect the positive and accidentally short the wrench to ground, it can cause a fire or even an explosion (hydrogen gas in the battery - remember the Hindenburg?)
If you disconnect the negative, shorting to ground with the wrench won't do anything, since it's already connected to ground.
Uncle Yaris is offline   Reply With Quote
Old 03-28-2009, 08:44 PM   #8
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
agreed, however this would only be if you touched the pos+ on the battery to a ground point on the car, regardless, good practice is to disconnect the neg-
Old 03-28-2009, 11:56 PM   #9
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
all that matters is that you break the circuit.
If one wanted to argue semantics... you could probablly prove that the negative terminal is the one to disconnect since power flows from the negative to the positive (Its the negative terminal that sends out power), but really... who cares... the answer is...
either is fine.
I always just yanked fuses..... usually I didn't even do that.. haha. A good distroblock should be fused as well as your power cable (within 8inches of the battery).
ACRONYM thread Shroomster Off-topic / Other Cars / Everything else Discussions 45 02-15-2025 10:30 PM
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 10:53 AM
Which of These Car Companies Will Go Bust First? *MAD DOG* Off-topic / Other Cars / Everything else Discussions 23 11-16-2008 10:50 PM
