Old 04-10-2009, 05:27 PM   #1
Grandieri
Grandieri's Avatar
Drives: 2010 Matrix
Check engine light AGAIN!
Long story short while I was in seattle for vacation my yaris threw a cel. I got it back to Spokane and was told it was a lean code that threw twice. Now four weeks later I have another cel. The only thing done engine wise is a cai by Fujita.They told me last time it could have been caused by the intake.But they recommended 89 octane instead of 87. So Ive been doing it since its first cel.Any ideas why? The yaris just hit 10k.Well anyways the damn thing goes in thursday.Im not rough on the car by anymeans its all highway driving most of the time.This time it came on from a start in first to get merging.Last time it was at idle.Thanks guys!
Grandieri is offline   Reply With Quote
Old 04-10-2009, 11:33 PM   #2
have you double checked the intake is installed properly, that there's no air leak at the joint where to connects to the throttle body? That's the usual suspect...
Old 04-11-2009, 12:30 AM   #3
Grandieri
Grandieri's Avatar
Drives: 2010 Matrix
Thanks Ill give it a shot.
Old 04-13-2009, 08:23 PM   #4
Grandieri
Grandieri's Avatar
Drives: 2010 Matrix
Well I checked all my clamps and everything is good and tight. the dealership replaced my air flow sensor today, they said to try it out and see if it fixes the code.Anyone else running into this problem?
Old 04-13-2009, 08:26 PM   #5
DerFlosser
DerFlosser's Avatar
Drives: Yaris
I am not having the problem but CAI in my experience are useless and can only cause problems with today's sensitive electronics.
DerFlosser is offline   Reply With Quote
Old 04-13-2009, 08:36 PM   #6
YarisSedan
Drives: 08 Yaris Sedan
If you are using a intake system with a oil filter you have to be careful since the oils can get onto the maf sensor wire. Now this coatst he wire and makes it kinda sticky and as dirt bypases the filter and it will since its high flow it will stick to the maf sensor. Usually you can fix this by simply cleaning the filter or what they dealer did by changing it.
Old 04-13-2009, 08:36 PM   #7
Grandieri
Grandieri's Avatar
Drives: 2010 Matrix
Yeah word for word exactly what the service manager told me.
Old 04-13-2009, 08:38 PM   #8
Grandieri
Grandieri's Avatar
Drives: 2010 Matrix
Fujita runs a dry filter. That was one thing i took into consideration.
Check engine light on kcty DIY / Maintenance / Service 19 03-10-2012 09:54 PM
Check engine light Geelmeel DIY / Maintenance / Service 7 11-29-2009 12:32 AM
check engine light twice within a week of purchase?? conurebuddy General Yaris / Vitz Discussion 8 04-17-2009 11:53 AM
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 02:43 PM
Check Engine Light Question falkor_99 General Yaris / Vitz Discussion 11 07-22-2007 06:15 PM
