Old 04-09-2009, 01:55 PM   #1
fuji
fuji's Avatar
Drives: Polar White Yaris HB
DIY Engine Dampener
The nitto engine dampener is really expensive for what you get. I it also not adjustable. It would really be nice to have a dampener you could adjust in both compression and rebound. Well, how about a mountain bike rear shock? It frequently can do both and can be found cheap on ebay. All you need to do is some fabrication of the mounting points. What do you guys think???
fuji is offline   Reply With Quote
Old 04-09-2009, 02:15 PM   #2
Dr Isotope made a few of these for the Scion tC, they were really cool.
It is incorrect to say that the NITTO is not adjustable.
I'm wondering if we could get just the brackets from them and source our own damper. Ingalls sells just their damper alone, might be a good call.
Old 04-09-2009, 02:49 PM   #3
YarisSedan
Drives: 08 Yaris Sedan
Hmm you guys may be on to something. Thinking like the chinese better and cheaper!
Old 04-09-2009, 03:02 PM   #4
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
SUBSCRIBED.....
Old 04-09-2009, 03:06 PM   #5
pixitha
Pixitha
That does seem like a really simple idea that should work great!
pixitha is offline   Reply With Quote
Old 04-09-2009, 05:15 PM   #6
Lambpasty
Internet Superhero
Drives: '07 HB Black Sand Pearl
SUBSCRIBED.....
X2
Lambpasty is offline   Reply With Quote
Old 04-09-2009, 05:24 PM   #7
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
The mountain bike shocks won't last. They are not designed for that kind of harsh loads. My mountain bike rear shock didn't last 2000 miles of street use, and that's on the bike.
Old 04-09-2009, 06:30 PM   #8
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
go-kart/golf cart shock then maybe?
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 04-09-2009, 07:02 PM   #9
fuji
fuji's Avatar
Over the years the shocks have improved. I would not use a ''air-only'' shocks but one of the more robust downhill coilover style shocks.
Are there any other possible sources for nice spring/dampener combos??? I like the golf cart idea.
Old 04-10-2009, 12:26 AM   #10
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
What about something like this , fairly inexpensive to boot at $55.00US
Does any body have photos of the bracket and there mounting postion.
Old 04-10-2009, 12:29 AM   #11
YarisSedan
not to mention it looks mighty wicked
Old 04-10-2009, 04:42 AM   #12
looks cool for sure... but might it not be a bit too soft? One would need to do the calculations in terms of leverage of course, but I have my doubts
Old 04-10-2009, 06:02 AM   #13
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
That really depends on what you are trying to achieve , if you want it for pure tracking aspect's then yes , you are probably right .
When comparing it to the likes of a nitto engine damper which is stuffed with rubber rings . Or we could think outside the square and look at a
more street able gas air filled shock that has the ability to be totally tuneable (to a piont ) depending on spring rate and gas pressure.
I could send one to Garm for testing with his rocket ship
cost wise it's 1/2 -2/3rd's the price of the Nitto , it might be worth a shot
it might not .We will never know until we try it
can anyone tell me the length of the Nitto (betwen hole centre's)
Old 04-10-2009, 07:42 AM   #14
yarstar
Drives: 2008 Absolute Red HB
Subscribed! You guys are constantly coming up with good ideas. I love Yarisworld!
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 04-10-2009, 12:32 PM   #15
fuji
fuji's Avatar
The bottom line is it looks like there are quite a few options for shocks. It also looks like you need a fairly stiff spring to help control the motion adequately.
The next big question is how do we mount something like this? Where should we mount it???
Old 04-10-2009, 12:40 PM   #16
Looking at our motors, it pretty much has to go where the Nitto goes now.
I'm going to buy an Ingalls damper and see about the length of it. That would be a step up from the Nitto design. I'll also measure and try to source a mountain bike shock with the same length if possible.
Old 04-10-2009, 12:53 PM   #17
fuji
fuji's Avatar
Here is a crazy idea - I was always thinking about trying to mount a shock (bike/motorcycle) somewhere on the top/side of the engine. If I remember correctly there are a couple of threaded holes on the bottom of the engine which have no screws and they are pretty good size. How about a piece of curved spring steel such as a leaf spring? It has just a little give. The point where it is mounted to the body or frame, a series of dampening washers could be used to cut down on vibration. They also usually have one side where a bolt can be used to mount it.
What do you guys think?? Easy, cheap and probably very effective.
Old 04-10-2009, 12:58 PM   #18
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
You guys are crazy. Just buy the nitto. ;)
DIY: Engine Grille Block BailOut DIY / Maintenance / Service 39 11-11-2017 10:33 PM
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 06:34 AM
DIY: Painting Engine Cover frownonfun DIY / Maintenance / Service 12 12-01-2013 12:07 AM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 11:53 AM
engine dampener? cali yaris Performance Modifications 15 11-24-2008 04:36 PM
