Old 04-29-2009, 09:40 PM   #1
YarisSedan
Drives: 08 Yaris Sedan
Dang our pcv systems sure do like to suck up oil!!!
Okay so i installed a oil catch can using the home made home depo filter.
After about 2 weeks i can already see a teaspoon of oil. I am figuring the way things are going the filter should be completely full by the time its due for another oil change. Cant belive how much oil is going into the intake.
I cant imagine without this mod how much oil buildup residue is going to be coating the intake, valves etc.
For the cheap cost and if you dont mind emptying the oil it catches every few months i would highly reccomend this for all members.
Old 04-29-2009, 09:44 PM   #2
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
That's why I have to install my catch can. That oil is coating the inside of my S/C and I'm not sure how to clean it.
Old 04-29-2009, 09:45 PM   #3
YarisSedan
1 word SEAFOAM!!!
Old 04-29-2009, 09:51 PM   #4
LtNoogie
LtNoogie's Avatar
I'm too lazy to search while I'm at work. Where is the Seafoam introduced? In front of the throttle body?
Old 04-29-2009, 09:55 PM   #5
YarisSedan
Behind the throttle usually. You can even take the tube of the pcv valve and get a areosal version of seafoam and spray it down. Will clean all the oil and carbon buildup off your intake manifold as well as clean your valves and any carbon buildup in the motor.
Old 04-29-2009, 10:01 PM   #6
LtNoogie
LtNoogie's Avatar
Ok, I'll look into that this weekend. Thanks.
Old 04-29-2009, 10:02 PM   #7
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
does the catch can go on the line that goes from valve cover to intake, or pcv valve to manifold?
Old 04-29-2009, 11:12 PM   #8
YarisSedan
pcv to manifold. Maybe ill install a second one to intake but i dont think that sucks hardly any oil at all.
Old 04-29-2009, 11:13 PM   #9
mikenacarato
SIPNDEW
Drives: 15 STI
ok, ive had a can i was going to use on another car but why not put it on the yaris.
Old 04-29-2009, 11:19 PM   #10
YarisSedan
best way is to let it suck in about half a can slowly. Then shut the car off and let it soak for a hour. Then run the other half to clean out the soften carbon and gunk. Then the car will smoke like something fierce.
Old 04-30-2009, 08:37 AM   #11
hatchbackkid82
Drives: .
where is the DIY for the catch can?
Old 04-30-2009, 10:12 AM   #12
BailOut
Steals terrorist's lunch
BailOut's Avatar
http://www.yarisworld.com/forums/showthread.php?t=5294
- Brian
Share the Road
Old 04-30-2009, 08:20 PM   #13
kenkyd
kanye
Drives: 11 Corolla S
Send a message via AIM to kenkyd
in the diy, the husky filter, do they not make it anymore? i search google and cant find one.
but wtffffff, i went to walmart, 2 home depots, lowes, hectors hardware, 2 sears stores, and a sears hardware. NO ONE has this type of filter at all. other than online where should i go?
kenkyd is offline   Reply With Quote
Old 05-03-2009, 07:54 PM   #14
TheSilkySmooth
TheSilkySmooth's Avatar
I think the engine needs some top oil going on the valve stems at cyl top. Maybe you got too much oil in your engine. I only put 3.5-3.75 Qt and have zero oil usage.
Old 05-03-2009, 09:03 PM   #15
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Damn. 3 qts fills my oil up within range
Old 05-04-2009, 02:51 AM   #16
Adriaan
In between cities
Adriaan's Avatar
Drives: 2006 yaris ce
hey kenkyd, home depot has it but by a differnet company. At home depot there in the air compressor section. Just take a photo of it, since they'll have no idea what your talking about with out it.
Adriaan is offline   Reply With Quote
Old 05-04-2009, 09:37 AM   #17
TheSilkySmooth
You must not be draining it all out Dont use ramps and make sure the drain plug is tilting to the downhill if you car is not on a perfectly flat driveway
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
DIY Oil Pressure Gauge Install LtNoogie DIY / Maintenance / Service 13 11-20-2009 04:13 PM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
