Old 05-03-2009, 06:40 AM   #1
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
Question My springs still creak after 2 1/2 months!
I installed my DFs in the middle of February and noticed the back springs (maybe just the driver side, I can't tell for sure) creaked when I got out of my car. Well I figured they were just settling, and the creaking would go away but it never did. When researching my rear sway bar install I realized that there wasn't torque specs on the shock bolts on the springs DIY and I just tightened them without much thought. I figured maybe I tightened them too tight and it was that joint creaking. Well when I installed my sway bar, I torqued the nuts to the correct spec, but it's still creaking a week or so later. I hate it, it sounds like some old POS. Any one know why it's still creaking or what I can do about it?
Old 05-03-2009, 09:41 AM   #2
ruimond
Drives: Yaris YR
My Pedders springs creak abit when i get in and out of the car. Im not even heavy, lol. Must be pretty normal. I've had them on the car for about a year or so.
Old 05-03-2009, 11:02 AM   #3
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
You sure it's not your bushings? they are now at a different angle than stock and will 'travel' more.....I usually just spray mine with silicone spray (NOT PB BLASTER) and it kills the noise for a month or two....
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 05-03-2009, 02:52 PM   #4
CtrlAltDefeat
I ♥ Yaris
errr bushings? no I'm not sure... That's the inserts in the ends of the shocks that the bolts go through right? The cars only 9 moths old, why would the bushings creak?
Old 05-03-2009, 05:31 PM   #5
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Like previously stated spray silicone lubricant on various spots in the rear suspension until it stops. could just be something with a little bit of surface rust.
Old 05-03-2009, 06:42 PM   #6
IllusionX
Drives: 07 Yaris Sedan Aero
btw, when you remove a bolt from the car. lub it. If you removed it once, chances you will do it a 2nd time. so you really don't want it to seized up.
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 08:37 AM
TRD Springs Vs Tanabe DF210...The Title Bout detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 47 05-23-2009 10:02 PM
Which lowering springs should I choose? Danish Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 40 03-28-2009 05:56 PM
What springs should I get? Help! CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 01-26-2009 06:32 PM
Tein Basic Damper Coliey's Vs. Tein S. Tech Springs ToTo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 05-07-2007 05:08 PM
