Old 04-18-2009, 07:01 PM   #1
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
maintenance required
How do you get rid of the light it says i need a oil change i did it but the light is still there. Do i need to go to the dealer?
Old 04-18-2009, 07:07 PM   #2
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
turn the Trip meter to the "A" display, turn off the ignition, and hold the button for the trip meter down while you turn on the ignition again, you dont have to crank the car, just "on", hold the button untill the bars go across the trip meter and flash.
Old 04-18-2009, 07:19 PM   #3
Yoda
Yoda's Avatar
thx will try it later
Old 05-12-2009, 11:20 PM   #4
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
i'm going to try this :)
Old 05-13-2009, 12:17 AM   #5
ctrj
Drives: 07 Yaris Sdn, 97 4Runner
Don't you people have owner's manuals???
RJ
2007 Toyota Yaris Base Sedan -5 speed
SOLD
ctrj is offline   Reply With Quote
Old 05-13-2009, 12:19 AM   #6
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
lol i just scanned through the oil warnings section after my oil was changed.. YW made me lazy lol
Old 05-13-2009, 04:05 AM   #7
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Or, you can do it the hard way. Disconnect the battery's negative terminal for five minutes, then reconnect.
Old 05-13-2009, 09:25 AM   #8
IllusionX
Drives: 07 Yaris Sedan Aero
i don't think that works. the light should be wired to the cluster's odometer, not the main ECU.
Old 05-13-2009, 11:15 AM   #9
yaris-me
Learn to Relax
Are you sure?
Old 05-13-2009, 11:34 AM   #10
MUSKOKA800
MUSKOKA800's Avatar
I'll assume my 2008 sedan doesn't have the maintenance light, or at least not associated with oil change intervals.
I've rounded 40,000 kilometers (~25,000 miles) in 13 months, do my own oil changes and have never seen, nor re-set any warning light.
Old 05-13-2009, 11:38 AM   #11
It's only for US cars... it's called an idiot light for a reason
*runs away*
Old 05-13-2009, 06:24 PM   #12
nemelek
DWEED
nemelek's Avatar
10,000 professional comedians out of work and we have an amateur doing double time on Yarisworld.
Old 05-13-2009, 07:46 PM   #13
tetzyamis
'09 5dr
tetzyamis's Avatar
Drives: 2009 Yaris 5-Door Bayou Blue
I tried this and it worked!!!
Thanks for the info.
2009 5-Door Yaris LB Bayou Blue Pearl
2009 5-Door Yaris LB Black Sand Pearl
tetzyamis is offline   Reply With Quote
Old 05-13-2009, 07:57 PM   #14
IllusionX
what did you try? disconnecting the battery ?
Old 05-13-2009, 07:58 PM   #15
IllusionX
Are you sure?
oh.. I am sure as in, there's no way the ECU knows how many miles the car has been driven, except the Odometer.
beside that, i do not know how else the idiot proof light can be activated.
Old 05-13-2009, 10:52 PM   #16
tetzyamis
'09 5dr
tetzyamis's Avatar
No, the one on the 2nd post.
Old 05-14-2009, 12:15 AM   #17
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
WWWHHOOOOAAA did dat muhfugga just insult US
This is where I need the Whackit smiley
Old 05-14-2009, 08:26 PM   #18
IllusionX
well, it's good sarcasm, somehow. :P
Results from 100,000 maintenance Nigal DIY / Maintenance / Service 22 11-26-2008 01:41 AM
Question about required maintenance gm830 DIY / Maintenance / Service 9 11-04-2008 04:14 PM
how much does the first maintenance service cost hans_fh DIY / Maintenance / Service 25 07-05-2007 11:01 AM
MAINTENANCE REQUIRED!!! SamDaYarisMan DIY / Maintenance / Service 12 10-10-2006 07:42 PM
