Old 05-15-2009, 01:09 PM   #1
philwept_33
Drives: Yaris 1.0 VVti 2003
03 Yaris 1.0 VVti Engine Swap, URGENT help needed.
Hi im new on this forum so hoping someone out there can help me out.
On Christmas day the engine let go, so to cut a long story short got another one and although its from a 2003 and a 1sz engine code its an earlier one as the PAS pump is on the front of the engine rather than electric one which the car already has.
I fitted most of it yesterday however some of the sensors are not fitting. The main concern its the cam shaft position sensor as its is a 3 pin. On removing the old 2 pin one it seems about 5 mm longer meaning it fouls the cam shaft.
Please can someone help me on this as its been going on for ages and getting expensive!!!
thanks in advance - phil
philwept_33 is offline   Reply With Quote
Old 05-15-2009, 01:15 PM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
you'll need an ECU and wiring harness to go with the new engine.
Originally Posted by xnamerxx
you nailed it sir.
Toyota Yaris Engine Map wariss Performance Modifications 5 03-15-2009 01:21 PM
engine swap complete! Adriaan Canada 3 03-05-2009 11:50 PM
