Old 05-19-2009, 01:10 AM   #1
Creeper
Creeper's Avatar
Drives: Silver 2DLB Yaris
Send a message via AIM to Creeper
yaris universe fog light help
ok if anyoen has installed the fogs from yaris universe i ahve a question. i will be running supplied switch with the factory relay. if i run the fogs to pin 1. put the relay in. Then do i just connect the ground and two switch wires to the stearing column? and if so which colors go to which pin? is that all i have to do in cabin or do i ahve to splice the wire at the auto shifter as well? only 3 wires on the switch from this kit. if you can help that would be great sorry its early in the morning and im half asleep typing this.
Creeper is offline   Reply With Quote
replacement fog light switch? yrsdrgn Cosmetic Modifications (Exterior/Interior) 4 07-17-2007 05:11 PM
Finally installed oem ebay fog light for hatchback Adriaan General Yaris / Vitz Discussion 6 12-27-2006 05:24 PM
