Old 05-26-2009, 11:22 PM   #1
xanekka
Drives: _
___
___
xanekka is offline   Reply With Quote
Old 05-27-2009, 12:07 AM   #2
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
It should be possible to wire both together, but you'd probably want to run a switch that can swap the audio signals. Not sure if you want two audio sources fighting over the amps.
You will need a separate 4 channel amplifier to power the car's stock speakers.
You will want to invest in a good carpc power supply which will monitor ignition status and automatically control startup/shutdown (and handle any voltage spikes which could harm your hardware). Since this thing uses a DC power supply, dependent on the voltage you could get a power regulator that can supply that voltage (carnetix has a few voltage regulated power supplies) instead of figuring out how to rewire an M2-ATX power supply.
taKuto is offline   Reply With Quote
Old 05-27-2009, 12:15 AM   #3
IsLNdbOi
IsLNdbOi's Avatar
Join this site / forum for all CarPC needs:
http://www.mp3car.com/
http://www.mp3car.com/vbulletin/
Not sure where to start (2009 yaris)... Faith87 General Yaris / Vitz Discussion 37 03-23-2009 05:35 PM
thewifesyaris - photo scavenger hunt thewifesyaris Photo-Video-Media Gallery 0 03-01-2009 06:02 PM
