Old 01-12-2009, 04:27 AM   #1
Jansen
Drives: Yaris Sedan
TRD High Flow Oil Filters
I'm trying to figure out if TRD filters are worth it. I found two, one seems to have a better flow rate but I can't find figures. Flow rate figures would be nice, if someone could get them.
TRD High Flow Oil Filters, $12
PTR14-00000-05
TRD High Performance Oil Filter, 4 Cyl $10
PTR43-33010, 98% at 20 Microns
Wix/Napa Gold 51394, $5
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 19
Amsoil EAO09-EA, $15
98.7 percent at 15 microns
Going to get Pennzoil Platinum 5W-30 after the break-in period, so trying to get a high flow, high efficiency filter.
Jansen is offline   Reply With Quote
Old 01-12-2009, 06:58 AM   #2
CB900F2
Drives: 08 Sedan
Jansen.... I am also in the Toronto area.. Where you able to find a local supplier for the TRD oil filters??
thanks
PTR14-00000-05
CB900F2 is offline   Reply With Quote
Old 01-12-2009, 08:19 AM   #3
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
TRD is a rebadged K/N oil filter......
Old 01-13-2009, 04:21 AM   #4
2006fronty
2006fronty's Avatar
Drives: 2010 Mazda3 iTouring
Sparks Toyota lists 2 different TRD filters for the Yaris, one has an actual picture (white can like K&N) the other one doesn't have a picture. It's kind of weird that they have 2 TRD filters, maybe one's better who knows???
Old 01-13-2009, 09:01 AM   #5
1stToyota
1stToyota's Avatar
A Napa Gold/Wix filter for $5...if you're doing 5K OCI with the Pennzoil Platinum, like I'm doing, no need to spend twice the money. The WIX filter is a very good, well constructed filter. Only difference at all with the WIX filter and the Wix built AMSOIL Ea filter is the media, because the AMSOIL Ea is a 25K/1 year OCI filter.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 01-13-2009, 10:42 AM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
if you're not over-revving your yaris constantly (which means you're revving to 6500 for long periods of time) why would you need a high flow oil filter?
what's more important is the dirt-catching ability of the filter.
Old 01-13-2009, 12:27 PM   #7
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
i dont get high flow oil filter.... isnt it high flow less dirt thats being filtered..dont get it.
Old 01-13-2009, 12:32 PM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
not necessarily. a "larger" filter is a higher flow filter because it's less restrictive.. with the same dirt holding properties..
but the lower the restriction the lower overall oil pressure you'll see.. by 1-2 psi.. not a big deal honestly, especially when you're running heavier oil in a forced induction application
Old 01-13-2009, 01:08 PM   #9
TheSilkySmooth
TheSilkySmooth's Avatar
Just a couple thoughts:
If the oil pump doesnt have an internal bypass relief, then the pump will force the filter to pass whatever it can pump - which means if the filter media is overwhelmed, the pressure will unseat the bypass valve in the filtercan, and NOW you got plenty of flow (though unfiltered). Hey, I suppose it doesn't have to be constantly filtered. Understand, on most cold starts under 20 deg F the filter is not working at all - its just bypassing until the oil warms up. The "gelled" oil just wont flow through the media. - the bro
Old 01-13-2009, 11:35 PM   #10
canadian_princess
canadian_princess's Avatar
Drives: '07 Yaris Sedan 'S'
Send a message via Yahoo to canadian_princess
does anyone have instructions for installation of fog lights on the 4 door yaris?
canadian_princess is offline   Reply With Quote
Old 01-14-2009, 02:24 AM   #11
YarisSedan
Drives: 08 Yaris Sedan
LOL way to hijack a thread.
Old 01-14-2009, 07:52 AM   #12
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
WTF random High flow filters sound like a joke IMHO. Just get a mobil 1 and run full synthetic.
Old 01-14-2009, 12:44 PM   #13
TheSilkySmooth
Why? Are they the best for the Yaris? How can you tell? What is "full synthetic"?
Old 01-14-2009, 12:50 PM   #14
TheSilkySmooth
Speaking of M1 filters, whom is the supplier? Still Champion labs or is it Hastings or wix. I heard it can vary by application. I's the M1 more restrictive due to a less porous "paper"?
Old 01-14-2009, 01:24 PM   #15
Tamago
Tamago's Avatar
Drives: UZJ100
it's funny that people assume that because Mobil is printed on the box that Mobil must make the filter ;)
i don't understand why people don't just stick to a "toyota" filter. they're inexpensive, of good quality (not just paper inside) and look great on the car ;)
Old 01-14-2009, 02:50 PM   #16
gid
+1 on that . Been using TOYO filters for years without an incident . Had good luck with GM oil filters as well . Used them and TOYO filters for '03 MATRIX , '99 PRIZM ( Corolla ) , 2000 PRIZM , and '99 Corolla . They're the same as used for the YARIS , 1st Gen XB , etc..
Old 01-15-2009, 12:34 PM   #17
TheSilkySmooth
+1 on the GM/Delco - they worked best on our Tracker and 1500 silverado v6 - the champion sold at wall mart as supertech didnt seem to work well on the chevy IDK why
Old 05-23-2009, 12:08 PM   #18
Jansen
Drives: Yaris Sedan
Ended up using the WIX filters with Pennzoil Platinum, since I couldn't find any specs on the TRD filters.
Motor Oil and filters Lafiro DIY / Maintenance / Service 94 03-15-2010 03:40 PM
FS AEM CAI w/dry flow instead of oil filter superfly78209 Items for Sale by private party 24 12-26-2008 10:43 PM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
TRD Parts MC-BPT Sponsors Classifieds Area 9 06-23-2007 10:51 AM
