Old 09-20-2006, 03:16 PM   #1
YamilR
YamilR's Avatar
Performance Brake Rotors
Even though this is not a performance car but I was wondering if anyone know if a set of Raybestos vented rotors will do the job
http://www.partsamerica.com/ProductD...e=2037&ptset=A
This one is for a mazda protege but I think that it will work
Old 09-20-2006, 04:05 PM   #2
SimmZ
Drives: 2k3 Cavalier & 2k2 Echo
Be VERY carefull when you buy those cheap drilled rotors. These manufacturer take OE style blank rotors and do thier own holes and slots in it. It look exactly like a real performance rotors, it's almost impossible to see the difference, but these blanks rotor are not mild to be drilled because of the metal used. The result is simple, when these drilled rotors are submitted to stress and heat, they just crack and break! I leave you imaginate what it can do to your car depending which speed you gone..................
There is even some real Brembo branded drilled/slotted rotors over eBay and in local shops who are blank Brembo rotors also homemade drilled who are also very bad and dangerous.
2003 Chevy Cavalier Ecotec - His car!
2002 Toyota Echo Sedan - Her car... FOR SALE!
SimmZ is offline   Reply With Quote
Old 09-20-2006, 04:17 PM   #3
YamilR
YamilR's Avatar
Thats why I put the link to Raybestos
Old 09-20-2006, 04:32 PM   #4
SimmZ
I don't think Raybestos do drilled rotors... this is probably some blank Raybestos rotors who are homemade drilled.
Old 09-20-2006, 04:35 PM   #5
YamilR
YamilR's Avatar
http://www.raybestos.com/usa/rotors.htm
It looks to me like they do
Old 09-20-2006, 06:53 PM   #6
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
I bought a cheap set of cross drilled rotors for my Malibu a couple years ago because I was going through a set of pads every three months. Never had a problem after that with wear on the rotors, nor warping or cracking and hadnt replaced the pads until I traded it in. Maybe quality is a crap shoot.
mikeukrainetz is offline   Reply With Quote
Old 09-21-2006, 09:39 AM   #7
nsmitchell
nsmitchell's Avatar
Drives: LB-Auto-PWR-ABS-Cruise-Springs
Raybestos is a good brand. They have been a trusted brand for a long time. Those look like good rotors too. The "PG Plus" rotors are intriguing. Stops 22.5 feet sooner and 3 times the pad life! I know what rotors I will get when the time comes!
nsmitchell is offline   Reply With Quote
Old 09-21-2006, 07:40 PM   #8
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Anyone know if that is a price for a pair, or only one rotor?
Old 09-21-2006, 08:37 PM   #9
YamilR
YamilR's Avatar
Thats the price per rotor
Old 09-22-2006, 07:00 AM   #10
Violin
Violin's Avatar
Tanks.
Old 09-22-2006, 04:38 PM   #11
BulletProofAuto
Drives: 00 itr
you have no need for drilled rotors, they will only eat up your pad and heat up faster due to the lack of mass. if you want some kind of design get slotted, but oem and brembo blanks are your best bet. when i track my car i use pretty expensive slotted rotors, but i don't know if they actually make a difference or not.
BulletProofAuto is offline   Reply With Quote
Old 09-22-2006, 05:31 PM   #12
tca4
tca4's Avatar
Drives: Yaris RS (white)
Especially on a little car like this i wouldn't think it would really make a noticable difference. But if you got a deep pocket go for it
tca4 is offline   Reply With Quote
Manual Yaris performance info? SimmZ General Yaris / Vitz Discussion 22 10-27-2009 09:27 AM
Wilwood Brake Set dngz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 42 06-23-2007 03:59 PM
Performance exhaust systems for yaris aucorium Performance Modifications 6 08-16-2006 08:12 AM
Removing third brake light lightyearsgirl DIY / Maintenance / Service 8 08-06-2006 11:26 AM
Toyota Performance Exhaust for Yaris HB bigsky2 Performance Modifications 16 06-02-2006 10:21 AM
