Old 07-12-2009, 09:33 AM   #1
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
Bending aluminum?
I have two of these antenna mounts. They're aluminum - not sure what type. How would I go about bending it further?
Do I have to take a blow torch to it and bend it slowly - or would that fatigue and weaken the metal too much? I kind of feel like if I just stuck it in a vice and just bend it that it would snap.
Old 07-12-2009, 11:09 AM   #2
Can you post a pic of the bracket?
Generally aluminum is tricky to bend without cracking, unless you use a form to ensure that you don't bend it past the minimum bend radius (which is about equal to the thickness of the aluminum). Also bends tend to crack less when they are made perpendicular to instead of parallel to the grain.
Old 07-12-2009, 01:29 PM   #3
Sodium Duck
╚══════════RN
Doh, I forgot to post the ones I took.
Grain appears to go on the path of the arrow. I don't think I have a shot at bending these. I may as well just go fab something up out of steel.
Old 07-12-2009, 01:40 PM   #4
If it's anodized, you won't be able to bend it for sure. Heating it won't help unless you have acetylene or oxy-acetylene -- a home/hobby torch won't get hot enough to make a difference.
Old 07-12-2009, 03:20 PM   #5
Brian
Brian's Avatar
Don't try to bend it. It will probably break. It was probably bent like that and the heat treated. If you try to heat it and bend it the aluminium will actually become weaker from the heat. It would be better to cut and weld or make one out of mild steel. Looking at that bracket more closely, it doesn't appear to be formed due to not having an inside or outside radius. Could have been machined out of a solid block.
Old 07-12-2009, 04:28 PM   #6
jdinrc
jdinrc's Avatar
Drives: 2009 Yaris Blazing Blue 3dr
I agree with Brian, that's a machined part. Depending on the alloy and temper, if you're careful and go slowly you could cold bend the flat slightly without losing too much strength (I wouldn't recommend trying to bend at the corner), however, like Garms says, if it's anodized you will destroy the coating. If you hot bend it you will probably lose the temper completely.
jdinrc is offline   Reply With Quote
Old 07-12-2009, 05:34 PM   #7
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Heating aluminum with a torch is tricky. Get it hot enough to soften it for bending and you're close to the melting point, which happens very suddenly.
Old 07-14-2009, 06:55 PM   #8
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
I'd say it's cut from an extrusion is which case the alloy will not like being bent at all. And yes it will fracture the anodised coating, only a problem if appearance is a concern though.
rob323 is offline   Reply With Quote
aluminum gas door panel ? where to get it? marcus Cosmetic Modifications (Exterior/Interior) 20 06-03-2009 03:24 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
Aluminum door sill plates "Yaris" joninatl Items for Sale by private party 14 12-30-2008 05:31 PM
aluminum rims changing ride guality? rg570lvr Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 10-23-2008 12:21 PM
aluminum underpanel turboyaris Performance Modifications 20 05-02-2007 12:39 AM
