Old 05-18-2009, 11:25 AM   #1
Lafiro
Drives: 06 Yaris Sedan
Need everyones opinions on Spring/Shocks combo's please
So my shocks are dead on my car.
Please don't try selling anything to me just yet, as I plan on leaving my job as of July 4th, hate it. Got to worry more about finishing college and starting my career, so I won't have money unless the GF buys this for me. Hasn't yet obviously lol.
So as of now, I have the TRD springs. At times, I love the ride, but because the shocks are dead, every pothole or bump, is a hard impact/makes the car feel like its bouncing around. Lots os small hills/bumps and the tires feel like they are coming off the ground causing the car not to keep full traction at higher speeds(50+mph)
I live in NYC, and every road/every highway is hell. I can not take the grand central parkway with the car because its turned into hell, with severe drops and harsh impacts on every single overpass. The LIE from exits 29 to 19, also has the same problem, not as bad, just bad bumps every 50-100feet. Making another harsh impact causing the tires to jump up.
My question to everyone that has changed from a stock ride is as follows:
1) What do you think I should do; Should I get the strusts and shocks to improve the ride?
2) Should I eventually go with TRD strusts and shocks?
3)Should I eventually go with Tokico(forget the spelling) strusts and shock?
4) Should I maybe change out the springs to something else and try different strusts/shocks?
5) I am not looking for the softest ride, although after riding in BMW's and Merc's, they all seem to have VERY nice suspentions, soft on the impact, and very stiff on the turns. I wish I had that on the Yaris.
Please give me your opinions on what should be done, because Im getting sick of the ride quality and I forgot how it was when the shocks were new/either way now there are 10times the # of putholes and bumps because the city isnt fixing anything. I also don't want to end up going with TRD strusts and shocks one day if this will only cause the ride to have an even worse impact on all the bumps and potholes I was just describing, you know.
I would appreciate it, thank you all.
Old 05-18-2009, 12:22 PM   #2
gwasabi
Drives: 07 Blazing Blue LB
tokico shocks
Most Satisfying Crew
Serious Business...
MunkyWurks Garage - 8088488794
gwasabi is offline   Reply With Quote
Old 05-18-2009, 01:05 PM   #3
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
I'm going with TRD springs and Tokico Blues, and a good alignment. For my purposes that should keep me happy for a while.
Old 05-18-2009, 06:06 PM   #4
MUSKOKA800
MUSKOKA800's Avatar
TRD all the way. You can't beat multiple components engineered to work together as a package for our specific application.
My sedan handles like on rails, even with the weak OEM (Goodyear LS) rubber. The ride quality is firm but certainly not uncomfortable. I am at one with the road, every crack, which can be good or bad depending on your tolerance level and willingness to compromise some comfort in favour of enhanced performance.
Old 05-18-2009, 10:37 PM   #5
I have the TRD's, but with the Tein S.Tech's. A bit harsh on the bumps, but it's not so bad around my area. Part of the freeway here (one time) made my wipers turn on (yeah, the vertical forces was that bad that it made the wiper switch go down to the on position).
Old 05-19-2009, 12:19 AM   #6
Lafiro
Yeah had that happen a long time ago, and thats what I DONT want right now.
Old 05-19-2009, 12:42 AM   #7
I'd get the adjustable shocks (can't remember which right now, but was it the HTS?), that way you can set it to soft for daily driving, and firm for the track).
Old 05-19-2009, 09:10 AM   #8
regal
Drives: 09 Yaris 3 Dr White LB
The adjustable FTS are way expensive for this guys needs amd there ain't a spring made that can keep up withit. Get the TRD springs save $100 and buy the Tokico Blues instead of the TRD shocks. Its a great firm performance street driving package (w/ a TRD rear sway bar)
regal is offline   Reply With Quote
Old 05-19-2009, 10:23 AM   #9
Lafiro
I'm starting to get the feeling that most of you' just change shocks to have a more firm ride. And yeah, this car is not worth me spending any more money on it other then to keep it running right. (Aint going to ahve a job as of July 4th to what I know now, so its eventually up to my GF for this) I just need information on something that wont keep making the inside of my car rattle like there is no tomorrow.
Old 05-20-2009, 10:40 AM   #10
regal
I'm starting to get the feeling that most of you' just change shocks to have a more firm ride. And yeah, this car is not worth me spending any more money on it other then to keep it running right. .
Wrong wrong wrong, I thought the same until I added the TRD suspension, it really turns into a performance handling go-cart which I am very into.
Old 05-20-2009, 10:44 AM   #11
Lafiro
But I want to make sure that impacts are not going to be narsh/interior rattling. Thats why if I can change these dead stock shocks, I can get a set on there to compliment the TRD springs nicely.... Im also following the thread about the adjustable HTS shocks and struts.. so maybe those may be the right choice, assuming it isn't going to be an arm and a leg in price?
Old 05-20-2009, 12:24 PM   #12
Sparks Toyota-TRD
Drives: Toyota/Scion
The TRD Shocks go for $419 on our website.
You can get them here:
http://www.trdsparks.com/displaypart...&parts_id=1104
TRD is something made for Toyota cars and it will add a nice performance gain to suspension. You will lose a little bit of ride quality, but TRD will be a little bit smoother than a lot of aftermarket companies.
Tim
Sparks Toyota-TRD is offline   Reply With Quote
Old 05-20-2009, 01:00 PM   #13
Find someone who doesn't like the Tokicos. For $100 less than TRD, why not?
Old 05-21-2009, 11:23 AM   #14
Sparks Toyota-TRD
You might feel the $100 difference in the ride comfort.
Tim
Old 05-21-2009, 11:40 AM   #15
YarisSedan
Drives: 08 Yaris Sedan
Uh oh... battle of the vendors 2 completely unbiased opinions =)
Old 05-21-2009, 11:42 AM   #16
Lafiro
oh wow, good debate going here, who else wants to join in on the fun! I can't want to see the victor of this thread.
I do not see the need to change springs, unless someone wants to trade some other lowering springs(less aggressive) for my TRD springs.
But ride quality is a must. I dont mind nice handling, the springs give me enough on their own. But I dont need to find myself hurting my neck when I change to TRD shocks, or Tokico shocks.....
Its very hard to get the right information because I don't know of anyone here in NYC with a modded Yaris. I did go to an event at Stony Brook the other day and saw a nice Hatch modded, with what looked to be a miniature coilover holding up the hood. Dont know where the driver was though... So no one can relate to the harsh roads here where I live. Unfortuntely.... half of my driving is on the bad parts of the highway, going to school, and seeing friends, the other half is good/perfect for a stiff suspension, going to work/seeing friends in that dirrection.
Old 05-22-2009, 03:37 PM   #17
regal
I think the Tokico's are very good performance shocks, they really snap the suspension back down, absolutely none of the stock nauseating bounciness. I'de say they are on par as Koni Reds.
Old 05-22-2009, 03:49 PM   #18
Tim
[ vendor wars, lol ]
"Might" is the keyword, which indicates a lack of real-world data to draw from. You probably haven't tried the Tokicos -- have you driven a Yaris with the TRD's? They are very good - but not $100 better.
I've installed both and driven the car with both. I liked the TRD's and bought them (from TRD Sparks, by the way) for my own car before the Tokicos were available.
You will not feel ANY difference in ride comfort.
