Old 09-26-2006, 08:42 PM   #1
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
SPEAKER IS TALLING TOOLS AND INSTRUCTIONS
how do you make your holes/wholes for you speakers and such and what about tweeters dont they have to be more exact bucause the size of the outeer ring pictures help what kind of TOOLS
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 09-26-2006, 09:26 PM   #2
ChinoCharles
Drives: LB
If you have to ask what kind of tools you'll need, why are YOU putting a stereo in a BRAND NEW CAR?! Call your friends.
Old 09-26-2006, 09:31 PM   #3
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
will work for parts
vodkalush is offline   Reply With Quote
Old 09-26-2006, 09:52 PM   #4
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
Tools? a screwdriver?
Old 09-27-2006, 12:01 AM   #5
johnnyfive
johnnyfive's Avatar
i would use a drill, hole saw, dremel, rotozip, router, use anything that will cut stuff, an exact-o-knife/utility knife, a file, sand paper, anything will work, and depending on the exact speakers, there may me a trim ring/surface mount setup that will cover up an imperfect hole ;)
johnnyfive is offline   Reply With Quote
Old 09-27-2006, 05:07 AM   #6
bigsky2
Cousin Vitz
bigsky2's Avatar
Tweeters: Hole Saw will do the job. Mount in the A Pillar garnish or the upper part of the arm rest panel on the doors. For better sound staging, I suggest the A-Pillar garnish. Your instruction manual should state what size diameter the hole needs to be. Get the appropriate hole saw and drill it using a power drill.
Speakers: You will need custom spacers. Look up my thread on spacers (templates) for the Yaris. This will require a band saw, jig saw, and possibly a router. Mounting depth is also an issue here, so if you have enormous magnets that extend the depth past 2.75", you will need a 1/2" spacer (thickness of the bracket).
Old 09-27-2006, 06:32 AM   #7
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
I cut the holes (carefully) for my tweeters with a utility knife.
