Old 06-19-2009, 07:10 PM   #1
hatchbackkid82
Drives: .
need help removing o2 sensor
Someone help. I've tried everything under the sun. Is there any easier way to remove the O2 sensor Losing my f*cking mind here trying to get this sh*t off. ANy other suggestions?
Old 06-19-2009, 07:12 PM   #2
hatchbackkid82
Drives: .
yes i've used the search bar and that was no help
Old 06-19-2009, 08:37 PM   #3
Brian
Brian's Avatar
Did you try an O2 sensor socket? You can also turn the car on
to get in warm but not hot and it should make it a little easier to
remove.
Old 06-19-2009, 09:33 PM   #4
06silveryaris
Drives: 2006 yaris
maybe spray some wd40 when car is cool let it sit for a while the give it a wack. is it the top one or bottom? Are you doing it with a open wrench? Is it stripping or just not coming loose? If it is not coming loose maybe just heat it with fire like muffler shops and try then.
06silveryaris is offline   Reply With Quote
Old 06-20-2009, 01:44 AM   #5
silver_echo
ekodrvr
silver_echo's Avatar
why are you trying to remove it already? only 2 years old? that seems like an awfully short lifespan... aren't you still under warranty? if under warranty, take it to the dealer...
i like this smiley...
silver_echo is offline   Reply With Quote
Old 06-20-2009, 01:15 PM   #6
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
Spray the thread area with PB Blast (really soak it) and let it sit overnight. Make sure the pipes are cool when you spray it. Get yourself an 02 socket and then it should come right off.
Old 06-22-2009, 08:21 AM   #7
hatchbackkid82
Drives: .
Adding a nitto mid pipe
Old 06-22-2009, 08:23 AM   #8
hatchbackkid82
Drives: .
Thanks guys, well i soaked it in PB blaster, used a O2 socket, used a torch to heat it up. I must have been going at it for at least a goood 45 mins before i was finally able to get it off. Has anyone else had this much trouble getting their O2 sensor off? It was a real PITA
Old 06-22-2009, 09:26 AM   #9
Klink10
Klink10's Avatar
Glad you got it off. If you would, please post your opinion on the performance gain or lack of after install. This has been on my to do list for awhile. Thanks
Old 06-22-2009, 09:58 AM   #10
hatchbackkid82
Drives: .
Will do. I'm having a friend finish it up, I been running open header since friday. I'll try and get a sound clip
Old 06-22-2009, 10:50 AM   #11
DerFlosser
DerFlosser's Avatar
Drives: Yaris
You shouldn't have any problem with just an o2 wrench and a .5" drive. Leverage is key with something that is "heat cycled."
DerFlosser is offline   Reply With Quote
Old 06-22-2009, 01:08 PM   #12
hatchbackkid82
Drives: .
Just got the car back, Sounds great, defintely more throaty, it's actually quiter than what i thought it was going to be. I'll try and get a video tonight
pieza para el sensor maf paveovisual Central and South America 17 09-10-2012 04:34 PM
Bad Air/ Fuel mixture sensor warning for ALL Yaris owners eric81 General Yaris / Vitz Discussion 31 04-21-2012 08:28 PM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
Bad Speed Sensor? dmehak DIY / Maintenance / Service 33 01-05-2011 09:17 PM
FS: DC Sports Header + New A/F Sensor Return of the Yarii Items for Sale by private party 33 11-19-2008 09:18 PM
