Drives: 2006 yaris Join Date: Jun 2009
2006 Yaris Help!!
Hi guys im new to this forum but i was wondering wether anyone had a wiring diagram for under the dash. Im installing neons and a new alarm and i dont want to accidently set off thge airbag! any help would be appreciated
![]() ![]() ![]() ![]() Drives: 2008 Yaris HB Join Date: Oct 2008
Attach your lighting wires to the fuse panel,there is a open spot on it that has 12v,use a tester and you will find it right away.then unhook battery and install your lighting.....never splice in to a power source already in place in a car,it jsut leads to shorts,fires,and big pains in the butt.
As for the airbags......no worries unless you start cuttign out wires under the dash,they are harder to make go off than you think......most are identified with yellow plugs.....but if you just use the fuse panel to make connections or the battery to make connections you are good. |
| Yaris review from 2006..lol | rningonfumes | Off-topic / Other Cars / Everything else Discussions | 10 | 12-02-2008 02:05 AM |
