Old 06-15-2010, 10:52 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
starter rebuild
anyone been inside the starter,hatch 07, to replace the bendix return spring, and have pics????
yaris9876 is offline   Reply With Quote
Old 06-15-2010, 11:34 PM   #2
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
Bendix return spring??? Shades of the 1930's!
Actually, this is a rather modern starter. For what it's worth, here's a diagram:
Sir A.Y. Atoyot is offline   Reply With Quote
Old 06-16-2010, 02:06 PM   #3
yaris9876
its sticking a little bit... I assumed it was a spring that pulls the gear back off the mechanism
after you let go of the key...Is it a clutch type thing nowadays??? I asked a starter guy
and he said replace the spring and 2 contacts ... he said he had seen some of these...
Old 06-16-2010, 03:08 PM   #4
The starter does have a clutch. The starter solenoid (or magnet switch as the manual calls it) does have a return spring. It is the smaller cylindrical part piggybacked on the starter. That could be the spring that he's talking about. If it is weak or the plunger's rusty that could cause the starter to stay engaged for longer than it should.
Old 06-16-2010, 03:21 PM   #5
127.0.0.1
OR
When the contacts wear a lot, the contacts arc and fuse together with the plunger copper ring briefly and causes it to stick. this would be the typical 'hit it with a hammer to unstick it' scenario
Old 06-16-2010, 03:23 PM   #6
127.0.0.1
replace the plunger and contacts
call these guys, tell them your starter model, and they should be
able to source you a plunger and set of contacts
http://www.nationsautoelectric.com/densoparts.html
Old 06-17-2010, 12:51 AM   #7
Sir A.Y. Atoyot
Drives: '08 5-door
This kind of solenoid switch is generally not repairable - you replace the whole thing. The cap is crimped to the barrel - not designed to be serviced.
Examine the gear teeth on the flywheel - if they are chewed up, it can cause sticking as well.
Remote Starter - Tail Light Problem Chrsto4 General Yaris / Vitz Discussion 4 10-31-2009 11:36 PM
Remote Starter Mistry In Car Entertainment + Electronics (audio / video / alarm) 1 09-14-2009 01:32 AM
Starter problem wormley DIY / Maintenance / Service 2 10-29-2008 09:56 AM
starter kill & horn help spechuy DIY / Maintenance / Service 0 10-20-2008 01:30 PM
Starter dragging YarisTom73 DIY / Maintenance / Service 5 08-27-2007 12:11 PM
