Old 04-19-2013, 08:32 AM   #1
Alexrahl
Drives: 2007 Yaris sedan
Mechanical oil pressure install
I need to know what fitting the yaris takes in place of the factory oil sending unit. I have an auto meter gauge I want to use. Prefer not to use a sandwich adapter plate. Thanks.
Alexrahl is offline   Reply With Quote
Old 04-19-2013, 11:37 AM   #2
^ You're going to run hot oil into your cabin? Yikes. I can look up the fitting I think.
I also used the stock location, that worked great. Electric gauge though, not mechanical.
Old 04-19-2013, 12:36 PM   #3
Alexrahl
Oh yeah I ran one for years on my 5.0 fox body. Never had any issues, key is to not use plastic tubing. Always ran the copper line and never had any issues, since I already have it I want to put it to use.
Any info would be great.
Old 04-19-2013, 02:45 PM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I've have had a mechanical oil pres gauge in my car since '05. Plastic line and all. I don't see what the big deal is. I even started the car with the line unhooked to purge the air out and it took almost a minute for oil to start coming through the line is so tiny. My old '85 honda has the fuel lines, and brake lines all running through the car.
Old 04-19-2013, 03:07 PM   #5
^ You guys are free to use those gauges if you like. I see no advantage to it at all, and I don't like the failures that I have seen, nor do I like running lines through the firewall. As you said, you don't get pressure right away either, how do you get a cold start reading if it takes a minute to reach the gauge?
It's all good, to each his own; the OP has a gauge he wants to re-use, makes sense to me -- trying to find that fitting size.
Old 04-19-2013, 03:16 PM   #6
Bluevitz-rs
The line is pressure used slowly. So on cold starts its up to full pressure after about 5 seconds
Old 04-19-2013, 03:17 PM   #7
Bluevitz-rs
Oil never gets to the gauge it's mostly just trapped air in the line. It's static, there's no actual oil flowing through the line.
Old 04-19-2013, 05:57 PM   #8
Foot
Drives: 2010 3dr yaris
I think the whole idea you can compress air but not liquid idea. Once there is no air in the line any pressure applied to the oil gives you an accurate reading anywhere in the line.
Foot is offline   Reply With Quote
Old 04-19-2013, 06:11 PM   #9
Bluevitz-rs
any air trapped in the line just makes the reading slower because air does compress, but the end result is the same reading. Pressure is pressure.
Old 04-21-2013, 07:19 AM   #10
Alexrahl
Still looking for info on this. Can keep stock oil sending unit as well. Just looking for info options. Thanks.
Old 04-21-2013, 07:21 AM   #11
Bluevitz-rs
You'll just need a "T" fitting. The sending unit is located under the intake manifold. Make sure to use an oil resistant thread sealant too.
Old 04-26-2013, 07:24 AM   #12
Alexrahl
Wouldn't there be specific size to the fitting? What are my options.
Old 04-26-2013, 08:29 AM   #13
Bluevitz-rs
Pretty sure it's just a standard 1/8 NPT fitting
Old 04-26-2013, 11:14 AM   #14
Alexrahl
Ok thanks. I wasn't sure about that.
Ultimate Turbo Pre-Install Guide Focus_Sh1ft Forced Induction Forum 7 09-14-2017 03:28 PM
Oil Pressure problem... Suspecting Turbo issue Parmas DIY / Maintenance / Service 16 12-13-2010 04:23 AM
Question about a changing oil level Goose DIY / Maintenance / Service 3 11-02-2010 10:32 PM
