![]() Drives: Toyota Echo 2000 Join Date: Sep 2012
Need Help with 2NZ ECU pinout
Dears , i need help with an 2NZ ECU Pinout , the story is that i did an engine swap for my Echo/Yaris ( model 2000 ) from the 1SZ 1.0 to 2NZ 1.3 , the problem is when i got the new engine i found that the ECU sockets is different from my old one , the first Pic is for the old ECU and second Pic is for the new one ( the pic is not mine i found it random from the internet while searching but it's the same like mine ) , the problem that i can't match the old wiring system coming out of the dashboard to fit the new ECU , also some problems like that engine Tep. lamp is not getting the right signal as My car is with the digital Dashboard so the Temp. is a lamp not an amber one , the big problem that when i try to connect the Diagnose device to do the diagnostic test the device is not responding which mean that the socket is not connected rightly , and for sure the Check engine lamb is not responding too
![]() so i am looking for this ECU pinout as all the Pinouts that i found for 2NZ look like the old socket ECU not this new one , I got the engine from the dealer as it's for Toyota echo/yaris 1.3 can any one help me out with this ! |
For the 2nd generation Yaris, the 1NZ and 2NZ have the same pinouts, but for the 1st gen it appears that they are different, since the ones I have for the 1NZ don't match the connectors on your 2NZ ECM.
I would recommend subscribing to the Toyota Europe technical site to download the ones you need: http://www.toyota-tech.eu/SearchPubl...px?PUBTYPE=EWD
Thanks a lot , i'll try this solution hope to find something :)
Drives: vios Join Date: Dec 2020
i also need this ecu pinout pls help
| Ecu Pinout? | karlblanchard | Performance Modifications | 6 | 05-20-2014 05:25 PM |
| ecu pinout and plugs | fugazzye | Performance Modifications | 0 | 02-24-2012 11:47 AM |
| ecu pinout 2006 yaris d4d | faiscamix | DIY / Maintenance / Service | 3 | 12-16-2010 01:58 PM |
| Yaris 2006 1KR-FE ECU pinout? | Yules | Performance Modifications | 4 | 06-23-2010 08:12 AM |
| ECU pinout | ChinoCharles | Performance Modifications | 78 | 04-08-2007 06:10 PM |
