Old 08-22-2009, 05:33 AM   #1
steveh74
steveh74's Avatar
Drives: 2006 Yaris D-4D
Help! Horn just stopped working.
Hello all! My horn just stopped working and guess what!? My warranty ended 4 days ago!! Anyway.... I have a European diesel model. Does anyone know the steps for troubleshooting a non-working horn?
steveh74 is offline   Reply With Quote
Old 08-22-2009, 06:13 AM   #2
check the fuse first... no idea if it is in the same location as our engine bays, but the back f your owner's manual should have a list and location of all fuses.
Old 08-22-2009, 06:14 AM   #3
steveh74
steveh74's Avatar
Awesome... I will start there 1st. Thanks!
Old 08-22-2009, 01:25 PM   #4
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
if the fuse isn't the problem.... you will most likely want to borrow a multimeter to start checking the circuits.
Old 08-23-2009, 11:43 AM   #5
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
actually after checking fuses AND HORN RELAY
I'm an idiot.....i deleted my post....
Old 08-23-2009, 01:47 PM   #6
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
^ my horn looks like a small speaker. works fine.
Old 08-23-2009, 11:00 PM   #7
Shroomster
Shroomster's Avatar
oi....I thought they had the little trumpet/snail on the face still.
hmmm guess not (just went and looked)
at any rate his might have that (or not) trumpet on it (as its an 2006 maybe)
Old 08-24-2009, 08:21 AM   #8
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
I'm pretty sure that if I dug around I could find the old J.C. Whitney "Ocean Liner Blast Horn" I had on a car in the '80s, and parts to put an ear splitting air horn system together. I've gotten fond of my tootly little Japanese horn, though.
Old 09-14-2009, 12:33 PM   #9
Lafiro
Drives: 06 Yaris Sedan
Oh no, my horn stopped working yesterday!
Driving though the city, I used it once for a second, then pressed it again and nothing happened. Today I try again and nothing. The fuse in the engine bay is intact, so I am completely lost!
Where is the horn in the car located? Maybe its a good thing it went because the stock horn is just girlish... lol
Edit: Just found the PDF file on this exact issue. Ugh, I really dont want to take apart the front bumper again :(
Old 09-14-2009, 11:31 PM   #10
Shroomster
Shroomster's Avatar
AHEM check the relay also
Old 09-15-2009, 08:45 AM   #11
Lafiro
What inside the relay itself should I look for? How do I know if that is damaged or not? Should I just take the car to Toyota?
Old 09-15-2009, 07:13 PM   #12
yarr_is
Drives: yaris
It's asking to upgrade to the HELLA Horns ...
yarr_is is offline   Reply With Quote
Old 09-15-2009, 11:27 PM   #13
Shroomster
Shroomster's Avatar
switch the horn realy with another relay (swap them in their places and then try the horn again) if it works after swapping then you need a relay.
and then it's to toyota for them to replace it...under warranty
Old 09-16-2009, 05:30 AM   #14
Bob Dog
DARK PHASE OF THE MOON
Bob Dog's Avatar
Drives: 07 liftback
let yota do it if its under warranty; gain without pain
Bob Dog is offline   Reply With Quote
Old 09-17-2009, 10:23 AM   #15
Lafiro
I tried this before I checked the relay.
They want to charge me $98+tax to inspect it, and if and only if they find the issue, they can then check to see if it is covered under warrenty. So I told the service guy, your telling me that you wont check to see first if this is covered because you want $98 first? No response.
I told him my engine is still making a sqeaking noise when its warm, and in drive, usually coming to a stop. Like going to a drive through. They didnt find the problem last time, no charge then. This time he also told me $98+tax, and only then can they see if its covered under warrenty. Else another $140 if its the belt.
I can not believe this. I told him I never had this bullshit from anyone else here before, and my warrenty was the same now as it was 4k miles ago when I was there. Whats the problem. I just got the same BS about they need money first, then they can check warrenty after they diagnose the problem and pay there tech.
Never again I am buying a toyota. Never again am I trusting anyone into selling me an extended warrenty for somewere around $500-$1000, I forgot, that has YET to do anything for me.
I wonder if I can get a refund of the remaining extended warrenty. Screw them at Penn Toyota.
horn
My car's electrical system just stopped working today..? jamhot18 DIY / Maintenance / Service 14 11-04-2018 01:40 AM
HELP! SRS light won't go off, horn doesn't work kudzu71 DIY / Maintenance / Service 11 08-18-2009 05:12 PM
How to disconnect horn from alarm ??? Yawesh General Yaris / Vitz Discussion 5 02-19-2009 06:12 PM
Toyota Premium Horn Meteorite_Marty Cosmetic Modifications (Exterior/Interior) 22 02-18-2009 11:28 PM
Horn broken, watch for finger RogueYaris General Yaris / Vitz Discussion 11 06-26-2007 10:16 PM
