Old 11-08-2009, 04:44 PM   #1
detroiter
detroiter's Avatar
Is it possible for the steering to "tighten" up?
I was wondering if it's possible that the feeling of the steering can tighten up at all? Maybe I'm just imagining things but I swear it feels like the turning of the steering wheel is greatly increased sensitivity wise. I havn't changed the camber or anything so I can't imagine that contributing to it. Only thing I can think of that I've done is when the car was turned off, that I was trying to turn the steering wheel as far as it would go left and right. I have a hard time believing maybe that could be the reason for it but I don't know if an electric steering system would be different from a conventional system. Perhaps I'm just imagining things but I'd swear it's tightened up as to what it was.
Old 11-08-2009, 04:55 PM   #2
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
I believe it's electronically controlled, and dynamic for your concurrent speed; but don't quote me on that.
maybe check fluids first?
Old 11-08-2009, 05:38 PM   #3
Kal-El
Kal-El's Avatar
Yes, the electric assist power steering does change its weight based on speed.
Very light in the parking lot, tight on the highway. It's brilliant.
Old 11-08-2009, 06:47 PM   #4
2009BBPliftback
2009BBPliftback's Avatar
I love my car but I'm not a fan of the electric assist steering its just downright artificial and has no feedback.. I've thought about pulling the plug on it!
2009BBPliftback is offline   Reply With Quote
Old 11-08-2009, 06:55 PM   #5
jimek
Drives: 2009 yaris hatch 5 speed
my thoughts exactly
if there was..or maybe is literally something you can just unplug to make it go away i probably would
jimek is offline   Reply With Quote
Old 11-08-2009, 06:51 PM   #6
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I personally like it a lot, but I believe there's a thread that deals with deactivating it... I'll post a link if I can find it.
Old 11-08-2009, 08:38 PM   #7
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Looks like it turns itself off after around 15mph:
http://www.yarisworld.com/forums/showthread.php?t=23062
Old 11-08-2009, 09:30 PM   #8
detroiter
detroiter's Avatar
what I'm saying is that the overall steering feel of the car is more "aggressive", almost like if you give the front end a negative camber job and the steering is "hyper" as compared to a factory spec setting. It's hard to describe. Imagine if when you make a left or a right with your steering wheel, it used to be a quarter turn to go a certain direction...now it takes 1/4 a turn to go that same kind of direction. Not that that's what my car is doing, but that is the kind of feeling I'm
trying to relay in words.
Old 11-08-2009, 10:02 PM   #9
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Have you checked your struts and control arms?
Old 11-09-2009, 02:50 AM   #10
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Tires and/or tire pressure can make changes in the way the steering feels. Check your air pressure, you may have a slow leak.
Old 11-09-2009, 06:25 PM   #11
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
hold on i think i read this right u r trying to make it tight as to the steering wheel?
If so Why?
Originally Posted by sw07gt
Old 11-09-2009, 07:37 PM   #12
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
I'm pretty sure it is just happening with no effort, and confusion eschews.
Colin Chapman disciple
Old 11-10-2009, 08:13 PM   #13
detroiter
detroiter's Avatar
PROBLEM SOLVED!!!
I solved the problem believe it or not. I followed that link up above that someone posted to the thread about when the power steering assist turns off after a certain mph. Well someone there mentioned that the electric power steering system on the yaris is TORQUE sensing and adjusts as needed. So I started getting a hunch that maybe THAT is what was going on with my car....Well from the other day when I was installing the intake on the car, I was trying to turn the wheels as hard as I could in one direction, while having to start the car and immediately turn them, due to the car stalling right away because of the stock intake being off. The car must have sensed it was taking some serious cranking to get the wheels to turn, so it applied a ton of "help" to make the steering column turn easier.
So that's why for the passed few days my car has been beyond sensitive when turning left or right, almost like hyper camber. So I went out tonight and disconnected the battery so the ECU in the powersteering would reset. Wouldn't you know, 20 minutes later I reconnect the battery and fire it on up, the problem was completely solved and the steering was back to normal!
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
Steering Wheel Spacers? BassAssassin Cosmetic Modifications (Exterior/Interior) 0 08-12-2009 12:52 PM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
