Old 09-20-2009, 06:48 PM   #1
GnomeBody
AD&D Dork
GnomeBody's Avatar
Drives: 07Liftback/07sedanS
Megan front strut bars Question???
Im trying to install Megan coilovers on my 07 lift back and the new front strut bar linkages seem like there a hair too short... I can't get them to connect to the main strut bar witih out like jackin it up to meet, witch I DONT want to do if its gunna bend something.... GGGrrrrr... stupid strut bars...
would it kill me if I left them detached???
So many Questions... so little time...
Mods: K&N filter, Megan Coilovers, Ultra Racing 19mm rear sway bar, Sun tachometer, Window Tint.
GnomeBody is offline   Reply With Quote
Old 09-20-2009, 06:51 PM   #2
GnomeBody
AD&D Dork
GnomeBody's Avatar
Its hard to see from the first image but I'd say its about an inch too short...
Old 09-20-2009, 08:31 PM   #3
kurokoma-kun
Drives: 2007 Yaris HB
I kinda remember struggling with this too. It's seems like I had to put the car back on the ground, so the weight could compress the springs. I'm thinking that made it easier to connect the bar on the strut to the end link on the front sway.
my yaris, kurokoma-kun
Old 09-20-2009, 08:43 PM   #4
GnomeBody
AD&D Dork
GnomeBody's Avatar
Cool, thats what I was hopeing
For a second there I thought I had the wrong Struts or something
Old 09-20-2009, 09:02 PM   #5
kurokoma-kun
Well in theory I guess you should to be able to twist + lift the sway bar endlink up to meet the new bar attached to the new strut. I just remember my front sway rattling pretty bad after install but it was easy to reach and tighten that bolt when the car's the ground.
Oh yeah if I'm remembering right on that new bar...you have to put a hex key/allen wrench in the tip? to hold it steady while you tighten, otherwise it just spins with the bolt
Old 09-22-2009, 01:08 AM   #6
YaYa1320
YaYa
YaYa1320's Avatar
I have same setup, jack 'em up and assemble one side at a time, thats what I did, and everything works fine... Is everything else good??? I had other probs, but this wasn't one of 'em...
YaYa1320 is offline   Reply With Quote
Old 09-22-2009, 01:11 AM   #7
YaYa1320
YaYa
YaYa1320's Avatar
Jack up the lower control arm one side at a time, and assemble when everything lines up!!!
Old 09-23-2009, 04:55 PM   #8
GnomeBody
AD&D Dork
GnomeBody's Avatar
I feel like a moron... Ive been calling them "strut" bar linkages but mean "sway" bar linkages... worst part is I just realized I did it.
Please everyone take a moment to point and laugh
...well on a different note, I got them to connect up just fine after I lowered the car back down.
Old 09-23-2009, 08:07 PM   #9
kurokoma-kun
It was just a brain fart, we all knew what you meant! So are you done??
Old 09-27-2009, 12:52 AM   #10
GnomeBody
AD&D Dork
GnomeBody's Avatar
Im done with my part. I still think the fronts need to come down another 1/4inch or so to be even with the rears, but I figured I give the springs a chance to settle before I bother with the height again.
Other than that, I still need to correct the camber and get a 4wheel alignment but Im taking it into a shop for all that. Ive been thinking of getting it corner balanced too if its not to expensive.
Ive already got the camber bolts for the front, but Im still waiting on garm to send me the shims for the rear. They are supposed to be coming in with the rear swaybar.
It already handles WAY better than it did before, I cant wait until its all done.
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 12:52 PM
Hit financial hardship, so some mods must go-CF wing, front & rear strut bars, braces Astroman Items for Sale by private party 69 05-08-2009 10:28 AM
Strut bar - To preload or not to preload that is the question YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-02-2009 10:38 PM
**NEW ITEM** Tanabe Sustec Front strut bars C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 04-27-2007 10:54 PM
C-ONE Front Strut Tower Bar - Installed & Impressions (Pics to Come) bigsky2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 01-10-2007 07:53 PM
