Old 03-10-2013, 12:17 PM   #1
manny305
Drives: 2011 yaris
2011 yaris HID wiring
hello people, i am new to the yaris world and i recently bought a good set of hid's for it (h4). although when i plugged them in, only the high beam worked. so i went on with the trouble shooting and ended up removing the high beam wire on the hid kit and moving the low beam to the high beam slot...they work fine. (i dont care for high beams, barely any dark areas in miami, low beam produces enough light anyways...) so now i got them working, except one of the lights flicker, i bought a relay for it thinking it was a voltage problem but it still flickers...
what do you guys think the problem could be?
manny305 is offline   Reply With Quote
Old 03-10-2013, 12:59 PM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
been discussed before...best way is to unplug the blue wire from the small box underneath the dash ..takes 10-15 minutes...the only thing is youll lose your daytime running lights but then again you can always turn on your headlight during daytime..:).. im surepost still here and i got great help from yaris members as well....good luck
Old 03-10-2013, 03:04 PM   #3
manny305
Drives: 2011 yaris
thanx dude this model doesnt have drl lights though
Old 03-11-2013, 10:12 AM   #4
marcus
toyota
marcus's Avatar
no drl? really... cause the flicker is due to voltage drop.. hid kits requires 12 v drl drops the volt down to 9-10v but i could be wrong. hope you get this figures out..good luck
Old 03-14-2013, 02:52 PM   #5
B2FiNiTY
B2FiNiTY's Avatar
Drives: Prius C
could be a bad ballast or bulb. Swap them to the other side and see what happens. first bulb, then ballast, process of elimination.
B2FiNiTY is offline   Reply With Quote
November 2011 Yaris sales: +160.2% Thirty-Nine General Yaris / Vitz Discussion 10 12-24-2011 03:13 PM
