Old 03-07-2011, 02:57 PM   #1
Jason@SportsCar
steering wheel hub adapter
sold
Jason@SportsCar is offline
Old 03-07-2011, 05:32 PM   #2
TickleTimeTim
Free Mustache Rides
TickleTimeTim's Avatar
Drives: 2007 Yaris HB
what is the cost new for these things?
Club SHIFT
TickleTimeTim is offline
Old 03-07-2011, 05:49 PM   #3
Jason@SportsCar
$89 for the NRG
http://www.racinglab.com/nrg-short-hub-toyota.html
$100 for the other
http://www.evasivemotorsports.com/Me...=WB_HUB_TOYOTA
Old 03-07-2011, 07:15 PM   #4
Do you have the boot for the WB hub, or just the part as shown?
cali yaris is offline
Old 03-07-2011, 07:23 PM   #5
Jason@SportsCar
Just the part shown. I picked it up used and the boot was missing... It did come attached to a broken steering wheel.
Our new setup does not use the stock steering column, so these are no longer of any use.
Old 03-08-2011, 01:39 PM   #6
rapev-8
Drives: toyota
any idea how to disable the airbag light?
rapev-8 is offline
Old 03-08-2011, 02:50 PM   #7
Jason@SportsCar
No, I don't have the stock dash in our car.
Old 03-08-2011, 02:59 PM   #8
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
Lmao
Originally Posted by sw07gt
JumpmanYaris is offline
Old 03-08-2011, 07:01 PM   #9
TickleTimeTim
Free Mustache Rides
^^^^hahah. i want to see this in person. its like a weee death-proof
Club SHIFT
Old 03-09-2011, 12:32 AM   #10
matthewai
matthewai's Avatar
Drives: it is kinda stock
are all the controls for the car on the right windshield washer / blinker controller ?
matthewai is offline
Old 03-09-2011, 01:40 AM   #11
Schizoprenia
Drives: Toyota Yaris 1.5 M/T '06
I don't quite get why you said it didn't have a provision to retain horn.
as for airbag i do believe a member here said something about by passing both the connector with a resistor, 5ohms IIRC.
if it's just some little wiring for horns to work im interested.
Schizoprenia is offline
Old 03-11-2011, 01:09 PM   #12
Jason@SportsCar
bump
Old 03-16-2011, 12:48 PM   #13
Jason@SportsCar
Bump for new ridiculously low price.
Old 03-16-2011, 01:51 PM   #14
To bypass the dual squib airbag you would connect two resistors across the two airbag connectors. 2.2 to 4.0 ohms are the typical values used for this purpose. As for the horn, with a hub adapter you lose the spiral cable (AKA clockspring). The spiral cable is a device that allows the horn and airbag wires to be able to be rotated back and forth without eventually snapping. Some hub adapters have their own version of a spiral cable to allow a horn switch to still remain on the rotating steering wheel. In a worst case, you could mount a switch to the dash and wire the horn to it.
CTScott is offline
Old 03-16-2011, 02:17 PM   #15
killer deal [bump]
Old 04-14-2011, 10:09 PM   #16
Jason@SportsCar
Update, found the horn wire harness for the NRG unit.
Old 04-15-2011, 03:29 AM   #17
Jerkratt
Jerkratt's Avatar
consider the NRG hub and horn harness sold. PM me your paypal info so I can send the money
"It hurts more when its wet"
Jerkratt is offline
Old 04-15-2011, 02:10 PM   #18
Jason@SportsCar
Sold, paid and shipped.
Thanks
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Steering wheel hub adapter spdfrk Cosmetic Modifications (Exterior/Interior) 7 02-18-2011 04:44 PM
Steering wheel adapter for TS sadha Yaris TS Talk 4 07-14-2010 09:32 AM
steering wheel hub adapter yrsdrgn Cosmetic Modifications (Exterior/Interior) 0 02-25-2007 11:14 PM
