Old 05-21-2009, 10:09 PM   #1
Creeper
Creeper's Avatar
Drives: Silver 2DLB Yaris
Send a message via AIM to Creeper
Spoiler painted for $25
got it painted now time to install....shhhh cost me $25 to paint :) again no instructions whats the easiest way to install? stick on with tape then drill or hold it up mark spots then drill and stick on?[ATTACH][ATTACH]IMAG0003.jpg[/ATTACH][/ATTACH]
Creeper is offline   Reply With Quote
Old 05-21-2009, 10:14 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
very nice :) hold the wing up snug, use a sharpie or a punch to mark the drill points, remove wing, drill holes, insert grommets, use stickytape for wing, stick into place, bolt it up.
if it's an ebay wing you'll HAVE to buy longer bolts. the ones supplied are too short.
i just did this for a YW member a couple days ago :)
Old 05-21-2009, 10:24 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
i recommend either using a step bit or 3 different bits
1/8 inch for pilot
then 1/4 for mid
then final size, what is it, 12mm?
Old 05-21-2009, 10:27 PM   #4
Creeper
Creeper's Avatar
its from yaris universe so it looks like the screws might be a bit to short. thanks for the help though
Old 05-21-2009, 10:28 PM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
can you shoot a photo of the profided hardware?
Old 05-21-2009, 10:39 PM   #6
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
wow, just 25 dollars to get it painted? Im having a headache now about mine..
Old 05-21-2009, 10:43 PM   #7
Creeper
Creeper's Avatar
yeah $25 a guy owed me a favor and happen to ahve his own paint booth so i jsut had to buy the paint.[ATTACH]IMAG0005.jpg[/ATTACH]
Old 05-21-2009, 10:45 PM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
those bushings will crush outwards when compressed?
they look metal!
Old 05-21-2009, 10:56 PM   #9
Creeper
Creeper's Avatar
they are metel. do I need to get new ones? from what i can figure washer goes on screw, screw goes on spoiler, bushing comes from inside the body panel for the screw to screw into and holds it in place. is that not right? its what came with it so thats the best i could tell.
Old 05-21-2009, 10:59 PM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
something needs to compress that metal bushing. set your camera on macro and take another shot of the bushing from a foot away :D
Old 05-21-2009, 11:01 PM   #11
Creeper
Creeper's Avatar
ill see if i can find that setting its a cheap old digital
Old 05-21-2009, 11:04 PM   #12
Creeper
Creeper's Avatar
i cant get a non-fuzzy shot of them, but they are metel and wide on one end with groovs to lock it into place. the other end without the enlarged ring around it is threaded about halfway down
Old 05-21-2009, 11:07 PM   #13
Tamago
Tamago's Avatar
Drives: UZJ100
ok hmmm... just be careful with the hole drilling, gotta get those bushings TIGHT in place
Old 05-21-2009, 11:11 PM   #14
Creeper
Creeper's Avatar
believe me drilling a hole in my car is going to be extremely hard for me to do and will be double checked about 100 times before that drill gets close to it starting out small and working up in the sizes
Old 05-21-2009, 11:19 PM   #15
Tamago
Tamago's Avatar
Drives: UZJ100
where in georgia are you? north georgia? if i end up in chatt soon i'm more than willing to drill the holes for you :)
Old 05-21-2009, 11:28 PM   #16
Creeper
Creeper's Avatar
middle west, in columbus.
Old 05-22-2009, 04:10 AM   #17
AlainMikli
AlainMikli's Avatar
you gonna sleep with the spoiler, right
To do: Supercharger…
Old 12-23-2009, 08:58 PM   #18
metalshark
MetalShark
Drives: 2008 Yaris LB
If those nut sleeves are like I've used, put a locking star washer and nut on the bolt with the star washer between the sleeve and the nut. Screw them into the insert and hold the sleeve and nut stationary with an end wrench while tightening the bolt to expand the sleeve below the panel. I'd slip in some RTV when installing these and put the bolts in with blue locktite to keep all water out.,
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
DIY Sedan Spoiler Install Kaotic Lazagna DIY / Maintenance / Service 36 01-19-2020 11:35 PM
BNIB: White painted oem lip spoiler mikenacarato Items for Sale by private party 6 12-19-2008 12:30 AM
RS SPOILER ... SAD aznbabiegrlx0x0 Cosmetic Modifications (Exterior/Interior) 42 09-28-2007 09:49 PM
RS Spoiler (Yes i tried to search it!!) hasher22 Cosmetic Modifications (Exterior/Interior) 2 08-23-2007 11:02 PM
Rally style spoiler in white for sale!! cheukli Items for Sale by private party 11 07-18-2007 09:02 AM
